mounting horizontal bathroom fan vertically. is it wrong?
Last Post 30 Nov 2009 05:13 PM by glenfotre. 5 Replies.
GAWUser is Offline
03 Nov 2009 07:03 PM
Is it wrong to install a bathroom fan in a wall even thought the instructions only explain installation between trusses, in a ceiling/floor?
I can't run the vent duct horizontal for the stated minimum length of 2-3 feet, but if I mounted the fan in a wall I could run the duct straight up without any bends.
Anybody got any ideas?
sustainable designer User is Offline
21 Nov 2009 06:17 AM
Most bath exhaust fans can be mounted vertically in a wall, in fact some installation manuals will mention that wall mounting is an option. I often mount fans in interior, never exterior, wall stud spaces because it avoids an additional large penetration through the "vapor barrier" in high-moisture area of the house and it doesn't reduce depth of attic insulation at that point (I'm in a cold climate in Wisconsin). The fan can be ducted to vent up or down, depending upon shortest route and most practical location for a wall cap. I avoid vents through the roof. The fan won't vent with a foot of snow over the roof cap.
GAWUser is Offline
21 Nov 2009 10:27 AM
Great.
22 Nov 2009 09:05 AM
Posted By GAW on 11/03/2009 7:03 PM
If the instructions don't mention wall install, then I would not do it, as the bearings will burn out quicker
GAWUser is Offline
22 Nov 2009 07:51 PM
That's what I was fearing, I imagine these fans were designed and balanced specifically for horizontal placement unless otherwise stated.
I thought about calling their support line but I imagine the person on the other end would know even less about the technical aspects than most people on this forum.
glenfotreUser is Offline
I'd contact the fan manufacturer for their opinion. If they say it is OK, get it in writing.
People Online People Online: Visitors Visitors: 256 Members Members: 0 Total Total: 256
