Gel Fireplace
Last Post 03 Feb 2011 10:46 AM by thagreen. 10 Replies.
wilsonleeUser is Offline
19 Jun 2010 07:59 AM
Gel fuel fireplaces give you the look and feel of traditional wood burning fire place without the infficiencies of a traditional wood,it takes only about an hour to assemble and can be placed anywhere you wish our moved later as your decor changes.Ready to enhance your interiors with the majestic gel fireplaces.
26 Jun 2010 10:20 PM
Couldn't you just use Sterno?
20 Jul 2010 04:45 AM
Thanks for the recommendation.
patanUser is Offline
09 Aug 2010 05:46 AM
It´s a little expensive isn't it?
19 Aug 2010 03:15 AM
There are many range in fireplaces.So go for the best one!
modpod77User is Offline
20 Aug 2010 12:19 PM
Can you give some information about Sterno, please.
I'm interested in this field, too Thank you so much!
[URL=http://www.regencyshop.com/Bar-Stools/c33/index.html]bar stools[/URL] clearance sale going on now...
20 Aug 2010 06:50 PM
If you've ever attended a wedding reception, you've seen Sterno burning under the chafing dishes...
21 Sep 2010 05:59 AM
electric fireplace offer a contemporary or traditional style to any home.these fireplaces mimic a coal.wood or natural gas burning fireplace and can be used in place of a conventional fireplace.additionally, with realistic fire technology these units can offer you an incredible fireplace surrounding with or without heat..
source:soothingfireplaces(dot)com
greencleaningUser is Offline
02 Jan 2011 09:27 PM
Gel fireplaces are portable. This means that you can easily move them to the areas that need additional heat. They do not require any sort of vent or chimney, and are considered one of the safer auxiliary heating sources.
Here's to you, your health and the health of your family. <a href="http://www.cleaningcleaner.com">Eco friendly cleaning</a>
BrockUser is Offline
21 Jan 2011 11:29 AM
I have been thinking about adding one of these to a room in our basement. The basement is zoned, but I leave it off and would like this room warmed up.
It looks like this runs on a standard 16 oz propane tank, non-vented and three heating levels with a max of 6000 btu The unit is normally $200+ on sale right now for $99.
http://www.northerntool.com/shop/tools/product_200374052_200374052
It looks cheaper to run than the gel, maybe not as pretty and you could refill your own propane tanks off a 20 gallon tank to save more.
thagreenUser is Offline
Brock hope you baught one cause they took it off the shelves!!
People Online People Online: Visitors Visitors: 178 Members Members: 0 Total Total: 178
