Seeking advice on room air conditioner unit
Last Post 04 Jul 2010 12:42 PM by arkie6. 1 Replies.
desertmarcyUser is Offline
03 Jul 2010 04:48 PM
I'm in the process of room addition construction. Block walls are going up. I was planning on just an evaporative cooler for cooling. I'm in hot, dry s. Arizona where these work well most of the time, but not well in humid July-August rainy season. I thought before construction gets to the point where adding an A/C unit will be impractical/expensive, I would explore the idea of having a room unit as backup for the evap. The room will be ~1000 sq. ft. & according to Consumer Reports calculator, would need a unit 15,300 +/- 800 BTU/Hr. I was thinking a through the wall room unit, not central, and definitely something energy star rated. I don't need a heat pump system--the room is going to have radiant floor heating. Any recommendations on brands, models or other ideas that I haven't thought of? Thanks so much.
arkie6User is Offline
Are you planning on any insulation on those block walls? If so, what kind and how much?
Have you looked into ductless mini-split heat pumps? Google for more info. There are some very efficient units available.
People Online People Online: Visitors Visitors: 176 Members Members: 0 Total Total: 176
