Anyone reusing bathroom faucets?
Last Post 06 May 2019 06:29 AM by HelenLewis. 8 Replies.
sunnyfliesUser is Offline
09 Feb 2011 10:36 AM
I want to reuse some bathroom faucets and shower fixtures I already own, but my plumber is frowning in the idea. Keeps mumbling about potential leaks and insurance claims. Has anyone else reused bathroom faucets? Some of mine are very high quality, others not so, but all have never leaked before and are in very good condition. Is the guy just being too cautious? Should I be looking for a different plumber, one willing to work with someone trying to stay green? Thanks.
09 Feb 2011 03:43 PM
I see nothing wrong with reusing faucets.  Of course, your plumber will not have a chance to mark them up in price.  By the way, some older faucets can contain more lead than some of the newer ones.
3cityblueUser is Offline
09 Feb 2011 05:07 PM
I'd be o.k. with using serviceable faucets. A little less so with a shower assembly. The faucets would be easy to repair/replace in case of leaks, the shower a little more difficult and potentially more damaging. Your plumber could easily be relieved of responsibility for leaks though. He only needs to guarantee the supply to the fixture connection, the fixture itself would be your liability. I am also certain his mark-up is another factor in his reluctance.
10 Feb 2011 08:04 AM
sunnyflies;
he is grumbling about not making any money on you as would most plumbers, there is nothing wrong with using them , but don't expect any warranty from the plumber if there is a problem. If there is a problem its all on you
ICFHybridUser is Offline
13 Feb 2011 03:16 PM
It depends on the fixture. Quite a few of them just aren't engineered for long service.
Before doing that I'd go down to the plumbing shop and make sure rebuild kits or parts could be had for the wear surfaces. Then, I'd buy two kits immediately, apply one and put the other in a place in which it couldn't get lost. If the cost of that is daunting, then it might not be worth it in the first place.
VolleyballUser is Offline
31 Mar 2011 09:52 AM
I agree with ICF, that is depending on your skill level. If you can do the repair when times comes, then that is your best deal. If you have to call someone, get new ones. Also how modern are the units? Gold units are so outdated. Also if your unit still uses rubber washers. While you may save a fixture, if it ends leaking a lot of water, you are actually less green. I've seen people live with a drip for months.
WalterBurtonUser is Offline
20 May 2017 09:08 AM
You can reuse bathroom faucets and shower fixtures.
HelenLewisUser is Offline
06 May 2019 06:24 AM
I had reuse some sink and some shower hardware few times over the years. After installation, there are leakage and all are in excellent condition.
But remember during installation make sure to hire an experienced residential plumbing service NJ because trained plumbers are able to handle their work with keenness as they seek to establish a long-term relationship with their clients.
People Online People Online: Visitors Visitors: 331 Members Members: 0 Total Total: 331
