Appliances, Lighting and Kitchen/Bath Fixtures
hot water recirculation pump
Last Post 13 Oct 2011 07:03 PM by
. 3 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
tightline
12 Oct 2011 12:47 PM
wasn't sure which forum to ask this. Just wondering if anybody knows, or has info re energy savings when a hot water recirculation pump is installed on an electric water heater.
NFC
13 Oct 2011 12:47 PM
No info on actual savings, or whether it is really worth it (payback) but you could put it on a timer so it only operates 5 minutes before you wake up (or whenever you normally find yourself waiting for hot water).
13 Oct 2011 01:35 PM
Recirculation pumps are usually a net energy hit, not an energy saver, but they are definitely water-savers. Only demand versions where you hit a switch/button to call the hot water end up saving energy.
If you install one, insulate both the supply & return runs with 5/8" wall closed cell pipe insulation and you'll do OK. (Available online, from Graingers, or plumbing supply houses. Box stores carry only 3/8" wall stuff.) In some states pipe insulation is now required on all hot water distribution plumbing for new construction.
I agree - use the recirc pump most of the time in the winter (where the lost heat isn't really lost) and use a more restricted timer in the spring/summer/fall to minimize heat loss. Insulation is good too.
Membership:
croccohvacusa
People Online:
