Appliances, Lighting and Kitchen/Bath Fixtures
Throwing in the towel on Whirlpool Hybrid care dryer
Last Post 02 Jan 2019 02:04 PM by
newbostonconst
. 2 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
patonbike
04 Dec 2018 05:53 PM
After < 3 years our Hybridcare dryer has failed. The dryer will not spin. We had someone come and take it apart and the entire inside of the dryer is caked in a thick layer of lint. We are good about cleaning out both the regular and hybridcare filters so this is a little bit of a concern - seems like a legit fire hazard. I am told the control board has failed and is $350 to replace plus labor (not counting labor already spent diagnosing, etc.). We ended up buying a new regular whirlpool duet dryer for $900 installed with a 5 year warranty. Probably should have gotten a warranty on the Hybridcare originally. At least we won't have to wait 2 hours for clothes to dry and deal with the noise anymore.
whirnot
21 Dec 2018 09:23 PM
That's a shame. We have had ours for almost 4 years.
Based on your post, I took the back off and cleaned it out. There was a ton of lint in it. The problem was a foam gasket where the air pipe goes from the heat pump back to the drum. The foam isn't thick enough, and in our case it was displaced as well. Should do a better job and last longer.
newbostonconst
We have a LG Washer/Dryer Combo.
Not a heat pump model but close. It uses a couple gallons of cold water to do the condensing for drying. I think it is genius.
It is 120 VAC and doesn't need to be vented. We put our cloths when we go to bed and they are done by morning.
https://www.lg.com/us/washer-dryer-combos/lg-WM3997HWA-washer-dryer-combo
I looked and looked at the heat pump models and then found this one. No holes in the house was a big one for me.
Membership:
croccohvacusa
People Online:
