Passing fireplace heat between floors, vents?
Last Post 30 Jul 2007 07:29 PM by PanelCrafters. 4 Replies.
benoUser is Offline
27 Jul 2007 08:19 AM
Hi there,
We design a 2 storey house, the first floor (slab on grade) has a large efficient fireplace (wood) and hydronic radiant floor, on the second floor we plan hydronic radiant baseboards. No ducts/furnace in the house.
There isn't much air flow between the levels, so I wonder what could I do in order to transfer the heat from the fireplace to the upper floor. I thought of installing some kind of vents in floor/ceileing, having a fan inside. Is this the way to go? Are there already such products on the market? (Canada/USA)
Beno
30 Jul 2007 01:44 AM
Check building codes on this, I had someone once that wanted to do the same thing with a wood burning stove, it was a big NO NO with the building/fire department.
Chris
30 Jul 2007 02:23 PM
Check into heat exchange systems.
benoUser is Offline
30 Jul 2007 03:02 PM
If I google it I get over 30 milions hits!
And a definition:
"What are heat exchangers? They are devices specifically designed for the efficient transfer of heat from one fluid to another fluid over a solid surface. "
Is this relevant to me?
Posted By beno on 07/30/2007 3:02 PM
Probably not. Now, if you were using a direct vent gas fireplace, add on fan kits are very common. Some of them include ductwork and a wall vent for sending the heat to another room.
People Online People Online: Visitors Visitors: 148 Members Members: 0 Total Total: 148
