roof top deck
Last Post 04 May 2008 05:20 PM by drewsteele. 7 Replies.
drewsteeleUser is Offline
02 May 2008 03:13 AM
Hi all - Im designing an 2 story ICF home and and am designing a rooftop deck over the back of the house. dimensions will be approx 30 x 40.
Any ideas or pointers?
thinking about structure (obviously) but also best system to protect against water penetration -
any thoughts greatly appreciated -
Cheers
Andy
neverestUser is Offline
02 May 2008 07:26 AM
We are doing 1 story with full walkout basement, attached garage with bonus room over it, and the bonus room just begged to have a rooftop deck via its access, don't know if that might work for ya, but we've got a nice deck off that...
02 May 2008 08:56 AM
Building a flat (or almost) roof that is fairly easy. But when you add occasional to regular foot traffic, it becomes much less easy. Our current solution is to start with roof trusses (1/4 in 12 slope), decking, a peel and stick bituminus roofing material, 2x sleepers, and finish with a aluminum decking material with builtin drainage channels that is designed to be waterproof unto itself. Hopefully this double sealed system will provide many years of dyr service.
igorya76User is Offline
02 May 2008 01:26 PM
i would suggest using a low slope roof using a pmr (protected membrane roof) your roof membrane will be covered by rigid insulation and held down w/ a ballast the ballast could be any number of materials i would suggest using concrete pavers as the ballast
to help w/ drainage u could also put plants on your roof
for more info http://hydrotechusa.com/
this system is used on alot in commericial highrise buildings to provide a garden and vegetation in busness districts but can also be used residentially
02 May 2008 03:32 PM
Thanks guys -
So what I have in my head already is:
layers in order int to ext:
trusses - or joists
decking
3" polyiso mechanically fastened to decking
epdm membrane
after that Im blank...
Final deck surface - Im thinking synthetic decking - trex or something
So question is
place trex directly on top of membrane - with no mechanical attachment?
if so - even if very tight wouldnt there be some movement with traffic thus potentially rubbing through the membrane?
place  network of sleepers the fasten decking to sleepers? Then same problem - sleepers on top of membrane?
I think you see my dilema -
Any links to systems youve used or details would be very appreciated!!
thanks
Andy
02 May 2008 03:34 PM
just checking out http://hydrotechusa.com
some good stuff - still digging in - but may find answers here
PatrickTUser is Offline
04 May 2008 10:40 AM
Andy,
You have a concrete house planed, why not go with a flat concrete roof? Hambro steel joists with a 4" concrete deck. We are doing this.
Not sure where you are building but there are products to seal the concrete and yet leave a nice surface to walk.
Patrick T
Patrick - I had definately thought of it and really like the idea. Can you share some details about your project?
i.e.
dimensions
how much clear span
floor depth -
cost of system - (cool if you dont feel like sharing that)
pics would be very cool too if you have em ; )
I'll aslo Check the Hambro site for myself -
also -
I read somewhere on this forum about these guys
http://www.structuresofusa.com/index.htm
thoughts?
People Online People Online: Visitors Visitors: 160 Members Members: 0 Total Total: 160
