Options for a cooler south side of house
Last Post 29 Mar 2009 08:17 PM by Jelly. 5 Replies.
james00cUser is Offline
26 Mar 2009 09:11 PM
Hi,
I live close to Phoenix (AZ) where as summer temperature can go as high as 115 degrees and sometimes even higher.  My house has a south facing slump block(http://www.airvolblock.com/cm/Masonry/Masonry_Slump.html) wall (28ft X 8ft) that turns into a heat sink as the outside temperature reaches 90 degrees. There is no insulation or drywall whatsoever on the inside.  I as looking ideas that can be applied to the outside of the wall so as to reduce the amount of heat that penerates the wall?  Thanks!
James
RichColoradoUser is Offline
26 Mar 2009 09:40 PM
White Paint.
want to buildUser is Offline
27 Mar 2009 11:23 AM
Look into a white or even reflective metal rain screen mounted on wood or metal studs giving you an air gap between the wall and the rain screen panels.
I suppose insulation under the rain screen would also help.
http://blog.buildllc.com/2008/03/rainscreens/
Or try this:
http://www.greenrooftops.com/
Bruce FreyUser is Offline
27 Mar 2009 01:00 PM
......or a portico, or even a canvas awning to shade the wall.
(thanks for the Greenrooftops link....I had not seen them before)
Bruce
27 Mar 2009 08:47 PM
The slump block is hollow on the inside and years ago I had a contractor inject foam into the blocks but that did not help much. I feel applying reflective paint will have the same effect. However, thank you all for your suggestions on rainscreen, green wall, and awning. I will look into it.
External insulation would be an option.
