Green/Energy-Efficient Design and Planning
Frost Protection Depth in Ottawa
Last Post 14 Dec 2011 01:34 PM by
boardom
. 8 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
mlennox
30 May 2009 03:49 PM
Does anyone know what the city of Ottawa, Ontario, Canada will accept as the minimum frost protection depth for the bottom of footings on new construction?
wes
31 May 2009 08:50 AM
Why don't you ask the city of Ottawa?
Wes Shelby<br>Design Systems Group<br>Murray KY<br>
[email protected]
mlennox
31 May 2009 10:17 AM
Posted By wes on 05/31/2009 8:50 AM
That was my plan, but of course they are not answering calls on the weekend so I thought I'd get an advance answer from someone who may know.
Weedwaka
14 Jun 2009 10:20 AM
about 48" I think
Polycore
14 Aug 2009 04:30 PM
48" should be sufficient. Alberta building Code calls for 48" and the climate is very similar. The only place I know in Canada with less than 48" is parts of BC (36"). Your best bet would be to contact any certified builder in the area, but I am sure that if you plan for 48" you will be fine.
Polycore Canada Inc.<br>www.polycorecanada.com<br>1-877-765-9267
Green Build AB
08 Sep 2009 11:28 AM
I live just south of Edmonton and it is 48 inches here.
TAGreen
12 Dec 2011 01:46 PM
The City of Ottawa bldg dept. indicated that the frost depth is set at 5ft minimum for heated structures and 6ft for unheated construction.
cheers!
12 Dec 2011 02:49 PM
Who cares - use a frost protected shallow foundation. Of course then you have an insulation thickness and distance out you have to ask about.
boardom
You'd have to get this spec'd by an engineer. I'm pretty sure it isn't defined in the current codes as a simple solution. Can't fathom why anyone wouldn't build this way these days though. Why people continually build clay swimming pools and call them basements baffles me.
Membership:
croccohvacusa
People Online:
