Paying Architect and Builder to learn about alternative methods
Last Post 27 Dec 2009 03:03 PM by jstelmack. 15 Replies.
Daniel MUser is Offline
29 Sep 2009 11:21 PM
I am in the design phase of a 2100 sq ft modern home. I have done a lot of research and am interested in Kama, Polycore, Speedfloor, Faswall and other non-conventional methods. The architect is willing to "look into it" at his hourly rate. Shouldn't he be the one who tells me about emerging technologies? I just had a builder tell me the same thing, that he could look into it for an hourly fee. The architect even recommended proceeding to construction drawings showing conventional methods and then having the vendors of the alternative products convert the plans. Seemed strange to me.
Eric AndersonUser is Offline
30 Sep 2009 08:03 AM
Might I suggest finding another architect who is a bit more far reaching?
On the other hand, most builders who use ICF and I assume SIPs can hapily build it from the plans for a stick built house.  Mayby they need some parts of it engineered but they should have the contacts to do that already.
If you are going that way, start with a builder that already does that method that you want.
alot of Architects don't do thier own structural work so  once the layout and asthetics of the building are done the archi does not need to be involved in modifications.  they would need to account for differing wall thickness though in the origianl layout.
I would get one builder to quote it stick built OVE but with good quality in mind.  Have him also quote double wall construction, larson truss etc.  IE maximum  efficiency conventional construction.
then get a quotes to build it in SIPS and also in ICF and now you have a good way to compare all the possibilitys
Cheers,
Eric
RioUser is Offline
30 Sep 2009 03:43 PM
Posted By eric anderson on 09/30/2009 8:03 AM
Cheers,
Eric
If you're going to have a builder go to all the time to generate an accurate price for all of the construction methods mentioned hopefully he will tell you that he will be happy to do so for a reasonable fee.
01 Oct 2009 08:50 AM
I agree they people should be compensated for their efforts.  My objective is always to minimize the time people spend on my projects so it costs me less,  as  opposed to getting them to work more for the same amount of money.  If I hire an Architect or and Engineer I expect to compensate them for their time.  On the other hand, before I go, I have a damn good idea of what I want and I make sure they have a defined problem that I need solved so I am not paying one cent more than I have to.  Also you need to be decisive.
Get quotes from multiple builders for any project.  I would get the quotes for the shell only so you have valid comparisons for  the cost basis.  I would be honest  with the builders and say that you are considering multiple construction methods and are shoping both quality and costs.  I would also think you would get quote from several stick builders for 2 options, "standard construction" and an upgraded framing package for energy efficiency.  The builder should be willing to do that.
Next you get a builder that specializes in ICF construction to bid the job and a SIP builder to bid the job.
I don't  think geting a single builder to quote all the possibilities is wise.  He is going to want to go with what he is most comforable with.
Good Luck
Eric
08 Oct 2009 11:24 AM
By way of an update, the architectural technologist (draftsperson) that is doing the construction drawings had some familiarity and was willing to educate himself in the alternatives for the same price as drafting with convential means. I think that is the way it should be.
In my job I am expected to keep up with new developments in the law and must attend continuing education courses each year. I could never charge a client for the time required for me to learn the law. I can only charge for time researching and analyzing how the law applies to the particular facts of my clients' situations.
Now that I'm outed as a lawyer, maybe that explains why everyone wants to charge me a premium.
08 Oct 2009 02:24 PM
Posted By Daniel M on 10/08/2009 11:24 AM
Lawyer? thats an automatic 30% upcharge
toddmUser is Offline
09 Oct 2009 07:52 AM
Alas, your problems are just beginning. In phase 2, builders will price learning curves into bids on unfamiliar construction systems. It is the principal reason construction is one of the stodgiest industries in America: it is more profitable to go with what you know, and safer, too, because builders ultimately rely on subs to read and follow manufacturer's instructions. (That is one scary thought.)
The design phase is pretty easy, actually. Manufacturers will point you to architects who know their systems, and distributors will point you to builders and subs who have used them -- both in the interest of heading off potential horror stories. But the basic constraint remains. You shouldn't stray too far from what's already been done in your part of the world. This is particularly the case if the goal of the new technology is speed, which likely will prove elusive in the hands of an inexperienced crew.
16 Oct 2009 05:46 AM
It is why one would not hire a real estate lawyer for a divorce.
You need an Architect that has SIP experience and a builder that has SIP experience.
If you tell us what area of the country you are in , the forum can help you with some contacts
16 Oct 2009 12:09 PM
I'm in the Pacific South West of Canada - Victoria B.C.
17 Oct 2009 04:52 AM
Posted By Daniel M on 10/16/2009 12:09 PM
seems like you should have a bounty of qualified Architects and Builders , you are in SIPA's back yard have you serched their website ?
www.sips.org
Bruce FreyUser is Offline
17 Oct 2009 06:11 AM
Posted By Daniel M on 09/29/2009 11:21 PM
Part of my job is to hire architects, engineers, consultants and contractors.  All of them should be paid a reasonable fee for their services and expertise.  A contractor's fee must also compensate for the amount of risk that they assume.
Unless you are doing something that is REALLY cutting edge, clients should not pay designers to "go to school".
We rarely hire a designer who is not very experienced in the type of project to be done.  However, everyone has to start somewhere and we have occassionally hired relatively inexperienced  but eager and enthusiastic designers who were willing learn what they needed, but there was no premium to the client.  I am less anxious to hire a contractor who does not have the appropriate experience.
Learning new stuff is one the most exciting parts of this business. A good designer gets inside the head of the client and really understands the client's requirements and expectations.  Keep looking until you find one does.
Bruce
bakahomesUser is Offline
21 Oct 2009 08:53 AM
I would suggest finding a builder whom you are comfortable with their ability to learn the new/unfamiliar product. I am a young builder, only 32, and am always looking out and seeking out new products and new processes to build a better home for the customer and a home that I can be proud of. Maybe seeking out a younger builder would be an idea, some older builders are set in their ways.
And concerning bidding out the project, I would be careful and make sure you are calling out what is being bid so you compare apples to apples. There are too many builders, and they give us all a bad name, that bid bare minimum on everything and use change orders to allow the client to upgrade to what they want...I seek out what the homeowner wants from the start so my price seems high in comparison but in the end they are about the same or cheaper (but the homeowner has gone through hell to get there).
When you are spending the amount of money a custom home costs and the amount of time with your builder that you will, don't just base the decision on money.
21 Oct 2009 09:37 AM
I sure wouldn't if I was an individual without much experience in those methods hiring "experts" who had no experience in those methods for my own home. If I was an experienced professional builder/contractor that could monitor them a bit more, I would have less hesitation.
energy_efficientUser is Offline
21 Oct 2009 11:06 AM
Daniel M,
Decide which construction type you wanted to go with, ICF, SIP, stick building. Have your house plan done for regular construction and then find the manufacturer you want to use product from in your area!, like ICF or SIP or other type of building material (maybe Solarcrete :) MAnufacturers can take your house plan and converting to they material so it can be cut. Most of the times you have to worry the exterior walls. Then find a manufacturer recommended builder who already used they system (ICF, SIP etc..) B.C. area is very advanced with new energy efficient building systems.
I hope it's help,
Joe
SierraSkierUser is Offline
18 Dec 2009 11:28 PM
This is exactly what I just went through. But the upside was my wife and I spent a year learning about efficient home construction. I did not say green home construction because if I hear another hippie tell me about what is green I am going to go ballistic. But as the other posters said above, find a builder who has experience with stick, ICF and SIP and they will be able to guide you once you have a plan together. My builder has a few questions that we need to explore now, but I now have confidence our house will work. Many architects hold themselves out to be into energy efficient building, but they are not into it enough to actually read a book about the subject. My builder on the other hand thinks efficient construction and or skiing 24 hours a day. He knows how to build and knows where the best powder is.
jstelmackUser is Offline
Daniel - I agree with several other responders.. First: Educate yourself about various methods available to you BEFORE selecting an architect or builder. Try to understand how each option will impact the overall project and lifespan of your custom home. Listing categories like: energy impact, long-term maintenance, longevity (history) of products/methods, pool of expertise available locally, cost, possible impacts on other trades, adaptability to future modifications/changes if required, acceptance of family members etc. Recruit manufacturers to educate you about their product or technology. Make an appointment with your local code official. Explain to them what you are trying to achieve and ask them what has been successful (or not) in your county/area. Use this forum for opinions/suggestions.
If you are compelled to use a particular architect to satisfy family or (other) reasons, explain to them that pay is commensurate with experience. If they don't know how to accurately represent a particular feature in the drawings, but are willing to learn, then they should do so on their dime. Lets pretend your expertise is in family law. A client walks in needing counsel on an issue of contract law. Would you accept the case and bill the client an hourly rate while you become proficient in contract law? Of course not. Although it would be nice...
There are so many new and promising products and methods available that sorting through them can be overwhelming. Make a logic chart. Determine the general picture of what you want to build. List specific goals. Use that as a filter in your search for professionals and products. Have the house drawn with detail explaining each and every component of the house. Leave nothing to "guess at". All features, finishes, fixtures should be defined in the drawings if at all possible. If not, research the cost of lighting, plumbing fixtures, appliances, flooring etc and identify what the allowances should be. When you bid out the house, identify exactly what the builder is bidding on. If you know the material and labor costs of finishes, fixtures and appliances etc. specify that those components are not part of the bid. But also specify that allowances for those components will be identified and made part of the final contract specifications document. Try to make the bid request as detailed as possible, listing out each component that may not be considered standard or customary. Along with the contract insist, on a specifications document which is developed from the bid request and contains all the details, responsibilities, allowances etc. Examples of spec doc details: If you decide upon walls "other" than traditional stick frame, the window and door frames on the interior will require additional non/standard mill work. The plumber and electrician may be impacted with a particular type if structural system. If using SIP's for the roof, the venting is handled a little differently. This could impact the plumber and/or electrician. Detailed specifics in the bid request and specifications doc will reduce opportunities for change orders down the road ($$$$). If something is spelled out in the spec doc, the builder or subcontractor has no standing to claim "I didn't know about all that". Removing finishes, flooring, fixtures and appliances from the bid will give you a better sense of comparison between bids. Add your allowances to the bids to get the whole picture. Make sure that you discuss allowances with interested builders. If they feel an allowance is not enough, ask them to explain why. They may know, for example, that labor on a particular feature is more then you estimated.
This approach may seem overly complex. Imagine the alternative. Chaos, confrontation and higher costs.
Goals - Set expectations early, minimize surprises, save money, be happy in your new energy efficient home!
SierraSkier - I started another thread to discuss "Green v. Energy Efficient". Hint: I agree with you (but don't want to hijack Daniels thread).
People Online People Online: Visitors Visitors: 275 Members Members: 0 Total Total: 275
