In 2009 we had a passive solor slab home built near Divide Colorado, the solor slab was a waste of money. Inovative Structures, Matt Freidell built the home and fan he put in is noisy and annoying.
We built in a high radon area and he did not advise us of this. The slab is poured on concrete blocks, which were poorly sealed from radon. The space below the slab acts as negitive air space and sucks the radon to levels of more than 40.
I had to seal all ventilation from the slab, and draw the air from the slab to the outside to get the radon levels under 4.
For us it was a waste of money, this is possibly due to an incompetant contractor, Inovative Structures. |
Do not use Inovative Structures, Matt Freidell, he did a poor job sealing with a vapor barrier and the space in the slab area created a negitive air space which sucked radon from the ground in our home. We had to seal the system and vent air from the space outside to get our radon levels to be acceptable. His system was a complete waste of money.
Divide Colorado
