Condo Conditioned Crawlspaces - Ventilation?
Last Post 24 Nov 2010 05:38 PM by cmkavala. 12 Replies.
whatever419User is Offline
14 Nov 2010 07:09 PM
Our condo HOA has hired a contractor to condition the crawlspaces in our attached 2 story 20 year old buildings located in south central Indiana (Bloomington). We have four connected first floor units that will be most impacted by the upgrade. The crawlspace below each unit measures approx. 1000 sq ft., but I believe all are connected via (just guessing) approx. 10' opening in support walls between units. The space below my unit is very shallow, approx. 16-24" high. So, rounding things off- 2000 cu ft under each unit x 4 units = 8000 cu ft total crawlspace. A new vapor barrier is being installed over the old and blueboard insulation placed on the cinder block walls. Some sort of sealing is being done to the floor joists and exterior vent blocked off with blueboard. In the middle of each first-floor unit, a gas furnace is in a utility closet which opens into the great room. It has a 6x12" floor vent into the crawl space to draw combustion air for the furnace. I was told by a worker, if they don't have this vent, one will be installed so that "air will circulate to the crawlspace." I don't understand this. If our living space is always warmer than the crawlspace, how will air move down? And if it did move down, would this small passive opening, be enough to take care of possible humidity/mold issues? Finally, with the crawlspace being sealed from the outside, will there be sufficient air for the furnaces?
15 Nov 2010 07:41 AM
I would be worried the most about the loss of the combustin air flow to the furnace. If this 6x12 vent is the primary source of combustion air then sealing the crawlspace will defiantly reduce the airflow available. This, in turn, could create serious backdrafting and efficiency problems for the furnace. I would seek immediate answers for these questions from the HOA and an independent HVAC consultant.
15 Nov 2010 06:31 PM
Clarifications & News: Turns out our crawlspaces are connected in pairs (not all 4 together). Vents will not be cut in floor, but don't know if they intend to cover existing ones. A duct will be installed on the plenum of each furnace to direct heated/cooled air into crawlspace. I don't know of any plan to replenish extra air required for this. OwensCorning FOAMULAR 150 2" rigid extruded polystyrene insulation is being installed. The ducts in the crawl are flex type (don't know about insulation). I am awaiting info on local regs re connected crawlspaces... Needless to say, I have more questions about heating the crawlspace - especially since it connects to my neighbor. The mgmnt company rep sent me "conditioned crawlspace" info that extolls the advantages of (essentially) heating our floor. But since our floors are osb or plywood and covered with carpet, how much good is it going to do for the living space? Thanks for all the input - a great help.
22 Nov 2010 03:30 PM
Pre-Thanksgiving UPDATE: We learned for the first time from a worker that a duct would be installed to the plenum on the bottom of our furnace to supply conditioned air to the crawl. ---------------- Email reply from county buildings department: * "Apartment construction allowed crawlspaces to be connected assuming that the floors over the crawlspace had a one hour floor/ceiling assembly..." * "combustion air grills should be fitted with a fire damper" * "foam plastic insulation shall be protected against ignition..." (I have heard fire-retardant paint will be acceptable) * crawl "shall be continuously supplied with a minimum of 1.0 Cubic Foot per Minute of conditioned air per 50 Square Feet of under floor space" * "No permit is required." ---------------- Question to forum: Apprx 1000 sq ft crawlspace- so, 1 CuFt x 20 = 20 cu ft/min? How do I find out if our furnace/AC is delivering this? We have a newly installed Bryant Evolution System Plus 95s Gas Furnace. Some (most?) of our neighbors will have 19 year old, less efficient furnaces. We met with 3 members of our HOA board re the crawlspace remediation - Q: Who is the designer/expert of the crawlspace modifications? A: A professional crawlspace remediation company submitted a line item bid. It was very high. They copied the line item list and submitted it to (2?) other companies. Specific questions about the design (how return air would get back from the crawlspace to the furnaces, etc.) were met with the same answer: The work is being done properly and "according to code." Q: Are you going to ask the other owners for permission to alter their plenum/heating system? A: No response. Their basic reply to these type questions was that the crawlspace upgrade was approved at the July membership meeting. That no minutes have been distributed and that numerous members missed the meeting did not appear to concern them. This job apparently does not require inspection by building department, but (we think) the HOA agreed to ask if the department would be willing to do it if asked. We said our concern was about whether our furnace would still work efficiently and also concerned about the quality of the air we will be breathing. Sorry if I haven't addressed all questions posted here (figgered this post was overly long already).
22 Nov 2010 09:59 PM
Whatever419;
I find it hard to believe that the work you are describing does not require a permit, if the floor now needs to be rated this is a major change and typically needs  permitting. Any penetrations thru floor will also need to be protected by fire rated dampers to maintain the 1 hour rating. Someone is not disclosing the whole story to the building official
23 Nov 2010 08:41 AM
Firstly, I don't know that I've ever seen a condo with shared crawlspace. How do you maintain your fire ratings?
Secondly, your description of the process doesn't sound right to me, or safe, for that matter. I think a lot of factors are not being addressed. I'm with Chris. You should contact building officals for a more detailed consideration of this project.
23 Nov 2010 11:50 PM
Things have progressed and it looks like there will be a permit and inspection.
23 Nov 2010 11:56 PM
Posted By wes on 23 Nov 2010 08:41 AM
... I think a lot of factors are not being addressed.
This is what the inspector wrote to me re Indiana code: "Apartment construction allowed crawlspaces to be connected assuming that the floors over the crawlspace had a one hour floor/ceiling assembly..." I agree that a number of factors were not initially addressed. I suspect the HOA board did not know what they were getting into and the crawlspace remediator also did not know the code requirements, etc. Thanks.
24 Nov 2010 07:06 AM
Posted By whatever419 on 23 Nov 2010 11:56 PM
Get a new remediator anyone not familiar with the codes should not be involved with the solution
24 Nov 2010 10:43 AM
Posted By cmkavala on 24 Nov 2010 07:06 AM
I have no say in the matter... and there is the outside chance that they would have found out this stuff as they as they progressed. To all my complaints/questions, the response was, "The work will be done according to code." Of course, the problem with this was, it was not going to be an official inspection, but one done by a board member (whose qualifications I now doubt).
24 Nov 2010 04:06 PM
I am not a multi-family expert, but I have always thought that the code requirements for rental apartments and for sale condos were quiet different. I know some years ago, an apartment owner, here in KY, tried to covert his new units to condos, and could not, because of the different code requirements.
24 Nov 2010 05:33 PM
Wes;
 Multi family is multi family, regardless of condo or apartments the same codes will apply. Most likely the apartment owner had deed problems in trying to comvert to condos.
Posted By whatever419 on 24 Nov 2010 10:43 AM
it is absolutely insane for someone to pass themseves off as a qualified builing inspector, they could be pontentially be putting lives at risk by their ignorance.
In our neck of the woods that is not taken lightly and is a felony offense
People Online People Online: Visitors Visitors: 215 Members Members: 0 Total Total: 215
