double shell home in hot climate cooling with earthTUBE cooled air
Last Post 09 Feb 2011 10:36 AM by zehboss. 5 Replies.
kitUser is Offline
28 Jan 2011 05:00 PM
IM AM ABOUT TO BUILD A HOME IN A REGION OF HOT CLIMATE,
SHORT WINTERS WITH TEMPERATURES BETWEEN 10-20 C (50-68 F)(NIGHT/DAY),
 LONG HOT SEASON  25-40 C (77-104 F)(NIGHT/DAY)
MY IDEA IS TO BUILD THE OUTER WALLS OF THE HOUSE, AND THE ROOF, WITH AN AIR-GAP OF 2'' BETWEEN 2 INSULATED LAYERS ,
THEN BRING IN AIR FROM PLASTIC TUBES BURRIED IN THE EARTH , AND FORCE THE AIR TO LOOP AROUND THE STRUCTURE WITHIN THE AIR GAP THAT ENVELOPES THE HOUSE, AND BACK INTO EARTH TUBES, THE TEMPERATURE AT 1 METER DOWN (3FT) IN THE EARTH IS CONSTANTLY ABOUT 20 C =( 68 F) YEAR ROUND.
I AM THINKING THAT IF I CREATE ABUFFER ZONE OF COOL AIR THAT SORROUNDS THE INNER STRUCTURE, IT ACTUALY SETS THE LIVING EREA IN A VERY COMFORTABLE MICRO CLIMATE.
SEPARATING THE EARTH COOLED AIR FROM THE LIVING SPACE ELIMINATES 3 PROBLEMS THAT MAY ARISE FROM INTRODUCING AIR INTO THE LIVING SPACE ITSELF AS DONE WITH AIR TUBE SYSTEMS IV'E READ ABOUT:  1) STALE AND MILDEWED AIR 2) THE ESCAPE OF COOLL AIR FROM WINDOWS AND DOORS 3) GREAT COOLTH LOSS FROM EARTH COOLED AIR.
SINCE THE BUILDING OF A DOUBLE SHELL STRUCTURE WILL BE MORE COSTLY, BOTH IN MATERIALLS AND IN LABOR, AND I HAVE NO EXAMPLES TO COMPARE MY PLAN TO, I AM SEARCHING ADVICE FROM ANYONE WHO HAS INSIGHTS IN TO THIS IDEA.
HOMES BUILT IN THIS EREA USE EXTENSIVE AIR CONDITIONING FOR COOLING.
IT IS NOT A DESSERT REGION WITH COOL NIGHTS SO THERMAL MASS OF ENVELOPE IS NOT EFFECTIVE HERE.
INSULATION IS GOOD BUT STILL THE HEAT LOAD OF THE CLIMATE IS VEREY HIGH.
I ASSSUME PRINCIPAL HEAT MOVEMENT TROUGH THE WALLS WITH COOLED AIR GAP COMPARED TO WALLS WITHOUT COOLED AIR GAP CAN BE DONE RATHER SIMPLY,  FOR ASSESING VALUE OF THIS SYSTEM I AM PROPOUSING TO USE, BUT I LACK THE KNOWLEDGE TO DO THESE CALCULATIONS. CAN ANYONE HELP ME WITH THIS?
ICFHybridUser is Offline
28 Jan 2011 08:04 PM
You might try starting with the amount of heat coming through your outer dome and the volume of 68F air that would be needed to cool the inner surface of that outer shell.
That will help give you some idea of the outer dome construction necessary and how much earth tube air you will have to generate.
28 Jan 2011 08:52 PM
Kit,
Unless you only have caps, please turn them off.  In our world, using caps is like shouting for attention.
As far as research is concerned, there should be plenty since this concept was extensively developed and discarded in the 1960's and 1970's.  Search for envolope homes by an architect named Lee Porter Bulter who really developed and promoted a similar system to what you have described.  The envelope home supposely operated on a passive loop system from the crawl space up through the air space between the double studded insulated walls.  Although these homes were fairly comfortable, instrumenting these homes determined that the passive flow did not move enough energy to accomplish much.  The comfort level and energy savings were then attributed to the extra insulation in the two walls.  As a consultant living in South Carolina at the time, I received some training on designing and building envelope homes and was involved with some of the early examples.
I have also designed and installed earth cooling tubes.  One has to be very careful working with earth tubes because of condensation - if they get cool enough to condense moisture out of the moving air.  Also be carefule about the type of material used for the earth tubes.  Study earth tubes throughly before designing and installing.  Also ask Dana1 on this forum.
kitUser is Offline
31 Jan 2011 03:45 AM
thanks for your detailed reply,
I am still searching for examples of structures that combine the double shell home with earth tubes.
there is difference in what I am endeavoring to design and construct from the double shell structures i have seen on the internet,
in the envelope homes i have researched there is a large
space between envelope layers,  and usually a passive movement of air using  a crawl space as heat sink , and these designs I have found, are planned for cold climates.
in this design I seek to create a narrow layer of air (mechanically mobilized) moving in a closed loop , between inner and outer layers of envelope walls and through the earth tubes,
the idea of putting the inner house in a cooler environment.
humidity if created in the process would be contained in the closed system and drained via sloping tubes.
since the gap between shell walls of the house is narrow I am hoping I can minimize extra material costs for the more complex wall system, for instance only one of the two layers
of the double wall need be structural while the second can be attached to the structural layer for support.
My main concern is the effectiveness of the cooling; I need to find a way of calculating the movement of heat between the layers and the outside / inside spaces in order that I can
estimate effectiveness and estimate r values of wall layers best suited, also if there were examples from existing structures and solutions I could learn from.
i don't know if the concept is novel, or if tried before, but it seems logical to me that it will work, now i have to estimate its value though.
if you have insights in to this idea i would much appreciate any further suggestions.
thanks again.
[script removed]
kitUser is Offline
31 Jan 2011 03:53 AM
thanks for reply
would you know basic calculation methods , formulas, to use for estimating movement of heat between layers of insulated walls and air ? for example, if external air is 40 c, wall is 10 r value and internal air 22 c, what would be the rate of energy loss from hot surface to cool surface ?
zehbossUser is Offline
Hey,
I have been building zero energy homes for over 30 years. Very few people build double shell homes.Larry Hartwig at http://www.zeroenergydesign.com/ is a Florida company that has a lot of experience in hot areas. http://www.enertia.com/ is one that is in the NE and builds and sells home packages. I am at http://www.zehtalk.com/ or [email protected] if I can help. I help people to build Zero Energy shells at no additional cost over standard construction.
Brian
ICF Solutions
Engineering, Designing, and Building Passive, Net Zero, Self-Heated, Self-Cooled, Self-Electrified, Low Cost Homes
Basic shell starting at R-50 Walls, R-80 Roof structures. for $30/square foot
(360) 529-9339
People Online People Online: Visitors Visitors: 225 Members Members: 0 Total Total: 225
