My family and I are in the design and budgeting phase of building, and have several questions that we would like some input on. Don’t take this wrong, but I want energy efficiency for costs savings sake. If it isn’t cost effective, there is no reason to add it.
A little about the house we are planning:
· 2900-3000 square foot main level rancher with full basement with daylight side. (minimum 10 foot ceilings throughout the house).
· Stick framed attic that is expandable into living space later.
· East Tennessee area.
· We plan on stick framing using 2x6 exterior walls. I liked SIPs idea, but there aren’t many distributors in our area making them cost prohibitive. I use OSB for strength on the exterior.
· We already use a tankless water heater, low-e windows, energy efficient appliances, high seer heat pump, Foam and batt insulation, and passive attic cooling (which still leads to a very hot attic).
· Brick and stone exterior.
Our questions:
1. Do you see any improvements to our energy efficiency?
2. Does anyone recommend a SIPs distributor in our area?
3. Will a radiant barrier as a housewrap help with costs? Does anyone recommend a supplier?
4. Does the 2x6 versus 2x4 really make that big of a difference?
5. Insulation in the walls – Foam and batt or Cellulose or foam? Is there such a thing as cellulose and foam? (I hate fiberglass).
6. What is required for a sealed attic?
7. Will a metal roof help with energy costs? Is it worth the extra expense?
I know, a lot of questions, a lot of general questions. I am researching what to do to death, but would like a nudge in the direction of some new ideas.
Thank you.
