Passive home construction
Last Post 04 Aug 2011 02:12 AM by zehboss. 30 Replies.
13 Jun 2011 08:18 AM
Also consider if you want to use treated lumber for the 1x2s against Hardi. I would.
14 Jun 2011 05:41 PM
Posted By bkcasa on 06 Jun 2011 01:52 PM
Wow. So much info to take in. I want to build a very tight well insulated house. I built the home we are in now, 2x6 and Hardi-Plank, it seems  pretty well insulated. We had fiberglass sprayed in. Now I am considering a double wall with hardi-plank siding and trim.
Will I be correctin building it with 2x6 exterior and 4x8 OSB sheer around entire home. 2x4 inside walls.I was thinking of 15 inchwall thickness. We plan on building in Washington State, near the Columbia or on the Peninsula.
I want to do alot of he work myself. I will have to pay to have foundation and slab in. We can do electric and some plumbing, cabinets, doors etc. I will look for help to frame it in and get gong on siding. Our living space wil be about 1200 square foot.
So will I need 1x2 to give me space between siding and OSB?
Insulation ? Spray fiberglass vs spray in foam or combo for best bang for the buck?
I plan on sealing all joints in the OSB. I have used Tyvek on top of OSB. Mu building experience is mostly in Arizona, warm and dry.
Rather than picking a wall thickness, design the thing for it's U-values and let the modeling determine how to achieve that reasonably economically.
Spray foam is an impossibly expensive way to go high-R.  It's primary benefit is the ability to get a good air-seal, but there are other methods than a full-fill of spray foam. Defining an all-6-sides of the cube air barrier using caulks, OSB, gypsum, edge & seam-sealed with the appropriate materials (including some spray foam) can be reliable. Test the air-barrier a soon as you have it all shelled in, before blowing any fiberglass or cellulose
Type-I EPS roofing insulation is a fraction of the cost per unit R, and for only a bit more than EPS fiber-faced polyiso roofing insulation gives you about R6/inch at PNW temperatures.  But it's still several times more expensive than cellulose.  If you buy recycled/reclaimed roofing iso it's typically 25-35% the cost of virgin stock, approaching cellulose pricing, and would allow a thinner wall at the same U-values than with EPS, fiberglass or cellulose.  Eg: 6" of iso + a 2x6 cellulose studwall yields about R60 (whole wall, thermal bridging included) if the iso is on the exterior and extends down to or below the foundation sill.  Add a couple inches for siding, rainscreen and gypsum and you're talking 13.5" from exterior paint to interior paint.  But you probably don't need quite that much R in the PNW to hit PassiveHouse levels.
With spray fiberglass you'll have to dense-pack it to perform well, and it'll be more expensive per unit R than dense-packed cellulose, but you can do a slightly thinner wall with it. (R4/inch vs R3.6/inch).  The performance difference in a simple studwall is negliglble, since the bridging of the framing reduces the whole-wall R to well under the center-cavity R, but in double-wall construction it can mean a wall done with 9" of new-school fiberglass performs about as well as 10" of cellulose.  You're paying a bit for the extra inch though.
Yes, you'd need some furring between the siding & OSB to form the rainscreen. Fiber-cement siding is a moisture-reservoir making the quality of the rainscreen even more critical.
Rather than going full-on PassiveHouse, in the milder parts of the PNW there's an economic argument for going R30-40-ish whole wall/R65 attic, and heating the whole shebang with a ductless mini-split, since you'll get better than 3.0 for a coefficient of performance out of a fairly cheap but high efficiency heating system.  Even a tight 1200' 2x4 house with R13 batts (~R11 walls) is easily heated with a mini-split in that climate if you have an open floor plan. (I'm getting my brother in Port Orchard off the propane tank and onto a mini-split in his open-floor plan home, hopefully before October.)  Building ~ R30 walls with no thermal bridging at the foundation, and R20 ICF (or R12 slab on grade) with an R60+ attic you could heat the place with even the very smallest mini-splits. It wouldn't run a high duty cycle, and could end up using similar amounts of electricity as a resistance-heated PassiveHouse at the COPs it would operate at there. The cost of the extra insulation to get the heat load low enough to use fewer kwh than the mini-split may cost considerably more than the mini-split. (Of course you'll still have to replace the mini-split every 15-25 years, whereas the insulation could last a century or more.)
A 2x6 cellulose insulated studwall with 3" of exterior iso comes in at ~R34 (whole wall), and is relatively easy to build, more than 2x the whole-wall R of a 2x6 fiber or opencell  foam studwall with no exterior foam (R14).   A 2x6 wall with 3" of exterior EPS comes in at ~R26, still almost twice the whole-wall R of a traditional 2x6. These are decent performance walls for Zone-4 climates, but you'd probably need R45-50 and some very careful design work to hit true PassiveHouse performance.  No matter what, once you're air-tight and over R20+ whole-wall , the window performance and thermal bridging of structural elements starts to swamp the heat-loss picture, so even if not going the whole way on R-values, DO pay close attention to all of those details.
15 Jun 2011 07:37 AM
Windows do limit the effectiveness of super insulation. I'm still looking for a good insulating window shutter design.
JohnyHUser is Offline
15 Jun 2011 12:28 PM
Aren't we all
ChalmersAbramsUser is Offline
16 Jun 2011 06:43 AM
These are all great posts.  Have you discussed your idea with a green builder or architect or are you planning to do it all yourself?  There are so many great products on the market today (as you can tell by this thread) that it can be overwhelming.  Even going to a green builder product supply store can be a great way to get ideas on energy saving, green ideas.  Good luck with the build.
zehbossUser is Offline
21 Jun 2011 12:00 AM
Hi, I build low cost zero energy homes. I live in Western, WA. The options above are not the best or least expensive in my opion. I would be happy to give you some advice if you want to give me a call.
Brian, (360) 567-6681
ICF Solutions
Engineering, Designing, and Building Passive, Net Zero, Self-Heated, Self-Cooled, Self-Electrified, Low Cost Homes
Basic shell starting at R-50 Walls, R-80 Roof structures. for $30/square foot
(360) 529-9339
vbUser is Offline
21 Jun 2011 10:27 PM
Zehbos, I'm sure you have some ideas worth sharing with the rest of us, after all this is a learning forum.
vbUser is Offline
Posted By vb on 21 Jun 2011 10:27 PM
Zehboss, I'm sure you have some ideas worth sharing with the rest of us, after all this is a learning forum.
22 Jun 2011 03:51 AM
I was on an internet TV show a short time ago that covers a lot of ideas related to this topic. The interview starts at about minute 23. It covers a lot of information and runs for over an hour. If you have any specific questions I would be happy to help. These types of homes are very climate and location specific. You should be able to build a net zero home for $100/foot any where in the US.
http://www.youtube.com/user/zehboss?feature=mhee#p/a/f/0/rT78iopvtD4
You can also review my website at http://zehtalk.com/ or give me a call. I teach, lecture, speak, engineer, design, help owner builders and contractors, work with code officials and build alternative low cost self-heated and cooled, carbon neutral homes. I have been doing this since the 70s.
Brian
ICF Solutions
(360) 529-9339
StyroHomeUser is Offline
01 Aug 2011 10:17 PM
If there is anyone interested in Passive, Net Zero Construction, using EPS Foam, here is the link to the Free Online Course. http://styrohomeconstruction.yolasite.com/school-eps-101.php
Usually these types of systems are overpriced. The foam in bulk is in the $3 to $4 per cubic foot of material. How much is this system? I have custom built a self-supported Polystyrene home with fiber reinforced surface bond cement previously. I started that project back in the 80s. The home was on a TV spot. This basic design should be public domain.
Brian
ICF Solutions
(360) 529-9339
People Online People Online: Visitors Visitors: 237 Members Members: 0 Total Total: 237
