Rinnai Combi
Last Post 28 Nov 2011 09:53 PM by jwessel. 2 Replies.
jwUser is Offline
27 Nov 2011 12:59 PM
Thanks for everyone's help so far. Stop me if I'm hijacking the entire forum. I have a Rinnai e75c currently on order. The house has a 50kbtuh load with what will be oversized cast iron and slantfin baseboard on the second story. Old loss was 80kbtuh. Does anyone have suggestions for piping the DHW? The unit has a built in heat exchanger, max input for DHW is 85kbtu. Max flow is 2.1gpm. Incoming waster temp is about 50 degrees. Rinnai promises a 75degree rise at 2.1 gpm. I don't know how it treats the DHW zone but I do know there is a mode to preheat the plate. The house has 2 standard 2.5gpm showers and 1.5gpm dishwasher/ laundry/ kitchen sink. 3 bedrooms but simultaneous showering is rare. I am considering DWHR for the main shower located on the second floor w bedrooms. Easy access to 8ft of 3inch abs waste pipe in closet. I don't think that will cut it without a buffer though. I think I may need a 20/30 gallon electric tank looped to the Rinnai. All is located in soon too be conditioned space. I am wondering if I should upgrade to the 110 model just for the 3.4 gpm of dhw? Or will that cost more in heat/cycling. thanks John
BadgerBoilerMNUser is Offline
28 Nov 2011 09:29 PM
Both space and water heating are almost always better served with a condensing boiler and indirect water heater. In used combi water heater/boilers one has to know the loads and the design temperatures of those load terminals. Be sure your boiler/water heater is capable of producing water hot enough for a high temperature emitter such as fin tube baseboard. As for piping. One should know before putting in the order, how any gas-fired appliance is going to be piped. The installation manual should be on line. Finally, there is the regular maintenance and support.
Professionals normally buy products from local distributors with direct or nearly direct access to the manufacturer. The distributor has hundreds of professional customers and a vast experience with the appliances he sells. Issues can be taken care of quickly. Before you jump in, perhaps a few phone calls to local contractors that service the Rinnai combi you are looking at and another to a local distributor for available parts...say a flow switch.
Just thinking...
jwUser is Offline
Badger, nice thinking. All I am trying to do here is "tweak" the piping to achieve max efficiency and maybe save a tree and a buck. Can you point me towards any reports/studies on real world short cycling losses? Concentric vent gains? Thanks
People Online People Online: Visitors Visitors: 221 Members Members: 0 Total Total: 221
