Green/Energy-Efficient Design and Planning
Sill plate question...
Last Post 01 Dec 2012 11:20 AM by
robert.thompson
. 3 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
robert.thompson
23 Nov 2012 12:51 AM
Can you use 2" (underground rate) foam insulation between the cement foundation wall & the 2 x sill plate? Assuming that you use 2 foam on the exterior that extends down below the rim joist & over part of the cement foundation, wouldn't this provide a real good thermal break? Thanks, Rob.
Rob.
http://googlevoiceforcanadians.com/
23 Nov 2012 10:19 AM
Unless that's one very wide sill (2x12 or larger) it's unlikely that you'd have the compressive resistance ratings for carrying the dynamic weight of the house, but that's something that could be engineered. To what end would be the question.
While 2" of exterior foam over the edge of 2x6 or 2x4 sill plate is a decent thermal break on the sill, unless that exterior foam extended below the local design frost line depth the thermal bridging of the foundation wall would be substantial. In many homes with uninsulated foundation walls the heat load of an unconditioned crawl space or basement exceeds 20% of the total heat load for the house.
robert.thompson
29 Nov 2012 11:37 AM
Posted By Dana1 on 23 Nov 2012 10:19 AM
Hi Dana1: I saw a drawing of a super insulated wall that showed a 2" foam sill plate gasket - no longer can locate the link. Rob.
Rob.
robert.thompson
I found the drawing. My mistake, it is an ICF foundation drawing, not a pure cement foundation: http://edgewaterhaus.com/wp-content/uploads/2011/06/1008_Normand_10-A3-2-1-2-Wall-X-Section1.pdf Rob.
Rob.
Membership:
croccohvacusa
People Online:
