Hello, fellow Hoosier here, I grew up in NW Indiana, Hobart. Hot humid summers & some pretty cold winter weather. 4" standard concrete can weigh about 50# / ft2 For my neighbors house here in Colorado, we put down 2x4 sleepers 12" OC & light weight concrete. 2 loops 1/2" pex / 8.5" concrete section, #2 Hickory flooring over. Looks & works pretty good. He has to run a little bit higher water temp. than tile over slab, but he wanted hickory. Higher water temps. will make a MODCON boiler a bit less efficient. Floor seems to output about 25BTU/ft2 at safe wood temp of 85* Keep your 1/2" O2 barrier pex loops at 200' max. spaced 6-12" depending on your thermal envelope. This will reduce pumping head = $ saved. I have very limited experience with boilers/radiant, designed & installed 3 systems. My next house will be using a small Burnham RV-3 cast iron boiler. Modcons don't condense much at 8,800' altitude where I live now. For NW In. I would look hard at Triangle Tube Solo boilers. At your altitude, with low return water temps. It will condense & self clean its vertical fire-tube type of heat exchanger, a very good thing. Great price/performance. Of course, as Badger always points out, hire a profesional (like him) to do heat loss & design system correctly the 1st time. Good Idea, but most heating/AC companies don't know Krap! So beware & good luck. BBP |
