Exterior foam -vs- interior spray foam
Last Post 15 Jan 2013 08:50 PM by WI HANK. 2 Replies.
WI HANKUser is Offline
11 Jan 2013 09:14 PM
Location: Western Wisconsin / St. Paul MN Eastern suburbs New Construction: 2 x 6 wood frame construction / above grade walls ICF - Basement Walls Fox Block Wall assembly 1 = Exterior foam board 2", OSB, interior cellulose insulation **About $1,500 - $2,000 savings over wall assembly 2 (More issues with window detail & siding install) Wall assembly 2 = OSB, high density interior spray foam *More expensive -has thermal bridging , no window and siding detail issues. Anyone with real world suggestions for me, as to what assembly I should go wit? Thank You P.S. Just finished framing house today.
whirnotUser is Offline
11 Jan 2013 10:02 PM
Usually you can go with the 2" Exterior foam without significant issues with detailing. More than that will require it.
Personally I am planning tht same wall system except using Zip panels and no house wrap. I will consider going to 4 inches of foam depending on the results of energy modeling.
Thanks for the reply Whimot, still on the fence on the direction I'm going. I was hoping someone would chime in on a real world experience, like someone who lives in a home in a cold climate w/ 2" exterior foam! Thanks Hank!!
People Online People Online: Visitors Visitors: 187 Members Members: 0 Total Total: 187
