Greetings All,
I've read many of the great articles concerning insulating this style of home (usually in the context of retrofit) but being a visual guy, I drew out what I "think" I understand about the subject, and wondered what everyone's thoughts were on the subject.
First of all, the design under consideration here is the typical 1.5 story "Cape Cod" style, which in my area (NH) almost always has a shed dormer on the back. They almost always have two "doghouse" dormers on the front, too - but adding those seems like it would make it even *harder* to insulate properly. This design always has minimal or no overhangs as well, to reduce wind grab in the event of Nor'easters, blizzards, hurricanes (rare), etc.
My thoughts:
- Instead of starting with a gable roof and adding a shed dormer, just make the shed dormer on one side full length. (Turns the design into a "saltbox" I believe)
- Frame with 2x6 on 24" centers walls, single top plates. Fill with spray foam, then rigid foam panels, then horizontal nailers for drywall. Vapor barrier is either provided by the rigid foam board, or would go on top of it. (Right?)
- Frame rafters and ceiling joists/floor joist/collar ties with 2x12, on rafters add in a nailing strip and another layer of (thinner) sheathing 3" from the exterior surface, glued/caulked/screwed in place.
- Break with tradition and add in 1' of overhang, divide soffit space so that an air channel is preserved, but that spray foam can be placed in the eaves.
...at this point, I thin a drawing helps to explain - blue shows cold air space to vented attic, green shows where the foam would go:
I think some blocking near the transitions and some more foam might help too.
The question: Is this reasonable? Crazy? Looking at it entirely the wrong way?
Thanks for your input,
-John-Eddie
