Jorr, Any duct or even grill will cause a pressure difference! It will always be best to leave the doors open. I'll make the 'grills' as large as possible. The hallway is bigger than any duct could ever be. With large return grills and decent air sealing of the house itself, <<1ACH @ 50 PA goal, The added heat loss, over a bare mini split, should be very small, but you are correct there will be some added loss due to infiltration. The added loss is, like the fan power, is a 'cost' of "distributing" the heat or cooling, that I'm going to pay. |
