Eliminating dryer vent (electric dryer only!)
Last Post 09 Jul 2013 08:34 AM by jonr. 3 Replies.
LieblerUser is Offline
04 Jul 2013 11:40 PM
Regrettably in the US there are NO vent less heat pump clothes dryers.  Obviously simply not venting would cause unacceptable heat gain and really bad humidity gain.  However,  With a small hack on essentially any conventional electric dryer it's inlet air supply can be collected to a single duct, it's outlet is already in a duct.  Now these two ducts can be routed to a "passive" HRV  ( a passive HRV has no fans)  and the other two ports of the HRV simply left open to the room.  The drain lines from the HRV are routed to the laundry sink.    The hot wet output of the dryer will be cooled and dehumidified by preheating the air flowing into the dryer.   Because both processes are imperfect I'd still expect the indoor air would rise in temperature and humidity but none of the energy would be vented.  Some of the energy used would be recovered so fewer watts would be used but the efficiency would still be well below what a heat pump could do.  NU-AIR makes what looks like a suitable passive HRV model NU120-2.  I'm ready to try it!
FBBPUser is Offline
05 Jul 2013 10:25 AM
Figure it will take more than a load and a half before the core is plugged with lint??
05 Jul 2013 06:39 PM
FBBP,
You are right lint will require more maintenance than a typical HRV. I see no way of predicting how bad it'll be. The NU-AIR has a filter for one air stream, I'll connect that port to the dryer output and see how effective it is, I'd start by checking and cleaning the filter after each load. Hopefully the core will be largely self cleaning as the condensed water caries what is missed by the filter. If i didn't live in such a backward country I would rather just buy a heat pump dryer as any European can.
This has been discussed here before, but consider making a tube in tube heat exchanger.
People Online People Online: Visitors Visitors: 162 Members Members: 0 Total Total: 162
