Ok, in light of new information from this forum and a ton of reading I have been doing, I woul dlike to know how the money looks to comare the following designs for my home overall. I would like to see what some of the items COST and the way they need to be configured to make the home work. My desire is to heat with wood, but i understand now that the large exterior wood boiler is not the answer. I wou ld like to employ a high efficency boiler inside the house if I can, along with a wood stove inside if I can. Primarily the boiler would do the hot water for the radiant system in the floor as wellas our domestic hot water. the wood stove would be for suplemetal heat in the home, so I will need another type mechanical system for heating and cooling in conjuntion with the stove. Make Sense???
Scenario #1...please provide input on HVAC System design and how to employ them together ( HRV/ERV...MINI SPLITS, boiler, wood stove)
2" rigid foam under basement slab and along edges along with radiant floor heat in floor, Zip Sheathing with sealed seams on exterior walls, 2" Rigid foam outside sheathing with sealed seams, 2x4 exterior walls with blown cellulose insulation. Bottom cord of ceiling rafters on 2nd story skinned with zip sheathing and sealed seams, 21" of blown cellulose in the attic, properly vented attic with soffit vents and . Gaskets on footers, gaskets on all sill plates, properly sealed window bucks, air sealed electrical boxes in exterior walls...the full deal, radiant floor heat in downstairs mudroom, two bathrooms, and hallway
Scenario #2
2" rigid foam under radiant heated basement floor, 2x4 framed exterior walls with zip sheathing (sealed seams), blown cellulose in wall cavities, zip sheathing on upstairs rafter bottom cord sealed seams and 21" of blown cellulose in attic, full vented attic with soffit vents and rig vent radiant heat in mudroom two bathrroms and hallway on main level
Scenario#3
2" rigid foam u nder basement floor with radiant heat, 2x6 exterior walls with zip sheathing sealed seams, blown cellulose insulation in wall cavities sealed zip sheathing on bottom cord of 2nd level celing 21" of blown cellulose in vented attic with ridge vent and soffit vents, radiant heat in floor through mudroom, two bathrooms and a hallway on main level
