Low Cost Passive Home designs for Hot & Humid Southeastern United States
Last Post 10 Feb 2014 01:46 PM by ricky_005. 4 Replies.
ricky_005User is Offline
10 Feb 2014 12:26 PM
Would love to hear your thoughts and ideas of what you think is the BEST LOW COST methods and construction materials for wall and roof assembles in order to achieve a true Passive Home in a Hot & Humid climate like the Southeastern United States.
Post your Ideas, links, and videos.
10 Feb 2014 01:19 PM
Very interesting concept...
http://www.triplepundit.com/2011/07...se-design/
http://vimeo.com/20839864
They dont go into methods other than the structural framing is built around an industrial pallet racking system.
10 Feb 2014 01:33 PM
Utilizing typical common framing practices here in the United States I will assume this is the cheapest route possible for Walls.
Now the tricky part ..... What about the attic ceiling or Roof?
sailawayrbUser is Offline
10 Feb 2014 01:35 PM
Not sure what your definition of “passive” is? If it is “true passive”, i.e., no mechanical or electrical assistance allowed, I don’t think you can get there in a hot and humid climate. AC is usually preferred/required in hot and humid climates. If your “passive” includes AC powered by PV, then you can certainly get there, but only a ROI analysis will tell you if should go there. True passive (both heating and cooling) is already very successfully accomplished in non-humid climates having diurnal temp swings.
Naturally here in the south if you want to stay comfortable you have 2 options.
  1. Live in a Cave
  2. Heat pump for space conditioning
Yes, passive home here in the south would have a bit different setup than northern passive homes. Shading during the summer months would be a more important design aspect for here in the south. So a heat pump for air conditioning would be necessary.
People Online People Online: Visitors Visitors: 302 Members Members: 0 Total Total: 302
