perlite under basement floor
Last Post 26 Jun 2016 08:30 PM by monkmaneric. 1 Replies.
LieblerUser is Offline
03 Sep 2014 02:52 PM
I had rejected perlite under my basement floor as too risky because of unknown compressive strength.  That was premature:  http://www.idosi.org/wasj/wasj25%2812%2913/19.pdf
 This paper clearly shows that expanded perlite compacted slightly (10% or so) will have adequete compressive strength.
http://www.schundler.com/underfloor.htm
Shows loose expanded perlite under a concrete slab and the perlite institute has a publication showing perlite left in bags used similarly.
So my plan is to cover the excavation with a "drainage" layer of pea gravel, build the PWF walls on the pea gravel, inside the enclosed area I'll lay down geotextile filter fabric then, place unopened bags of perlite loosely, then fill the gaps with loose perlite. compact the result with a vibratory plate compactor, lay one sided corrugated cardboard then 10 mil poly, then pour the floor.
monkmanericUser is Offline
Whats wrong with using rigid foamboard ?
Membership Membership: Latest New User Latest: IntegratedHomes New Today New Today: 0 New Yesterday New Yesterday: 0 User Count Overall: 35026
People Online People Online: Visitors Visitors: 232 Members Members: 0 Total Total: 232
