Manual J and europiean windows
Last Post 26 Oct 2014 12:29 PM by krom. 11 Replies.
kromUser is Offline
08 Oct 2014 08:23 PM
So I'm sitting here with my paper manual J, and the spreadsheet downloaded from ACCA's website.  I am trying to figure out what values to use for U, and HTM for custom sized European triple pane windows (looking at u PVC zola and intus as of now)
Intus is showing NFRC results of 0.18-0.33  BTU/(hr.ft2.F) on their website
Zola is showing "Overall U-value of 0.14BTU/hr.sqft", "glass U-value of up to 0.09BTU/hr.ft2", and "Performance of entire window
assembly shall be independently tested
and be a minimum of R-7 at a test size of
and be a minimum of R-7 at a test size of 1.23m x 1.48m"
I know that the glass is a better insulator than the frames, am I being too picky thinking that each different sized window should be entered with its own U and HTM?
BadgerBoilerMNUser is Offline
09 Oct 2014 07:07 AM
Too picky.
The right software would give you more options and accuracy. I you can afford triple pane windows, you can afford to have a proper heat load modeled by an experienced designer. If you then want to check their work--long hand--thereby still qualifying for your OCD meds.
kromUser is Offline
09 Oct 2014 07:32 AM
Guess its the engineer in me...
Should I just use the values for triple pane windows from the tables in the book for now?
Suggestions for an experienced designer in central NY (4-5 hours north west of the city).
Opinions on the value of having it HERS rated?
09 Oct 2014 08:30 PM
The book is close enough for the scale I assume you are building in.
11 Oct 2014 10:09 AM
Too picky.
kromUser is Offline
11 Oct 2014 12:25 PM
FWIW home despot quoted me $707 for a 36"x72" anderson casement (u 0.27 shg 0.18), while the quote for an intus tilt/turn is $839 ( u glass 0.088, shg 0.494)
Since U is measured differently, and the intus value is only for the glass its very difficult to compare. But the price difference isn't anywhere near as big as I was expecting.
Recommendations for software, or an experienced designer are more than welcome.
I'd prefer a designer, as buying quality software for a single small project doesn't make any sense.
Budget is only $100k excluding land, footprint is 28x40, ridge of the roof will be running east/west (almost perfectly)  The view is due east.
fun2driveUser is Offline
11 Oct 2014 11:50 PM
I posted for manual J suggestions regarding an expert calculation.
Here is the thread. I am sure the forum members that posted they can accomplish this task would also be able to calculate your manual J.
http://www.greenbuildingtalk.com/Forums/tabid/53/aff/14/aft/82784/afv/topic/Default.aspx
My situation requires a great deal more cooling than heating.
I saw your post on Andersen compared to Intus. I was surprised that the pricing was so close...
12 Oct 2014 07:35 PM
Posted By BadgerBoilerMN on 09 Oct 2014 08:30 PM
The location of the designer is irrelevant. All competent designers use ASHRAE data, usually in a Manual 'J' form such as our Wrightsoft program.
kromUser is Offline
13 Oct 2014 07:16 PM
I'm looking for someone in NY, because I didn't think that there would be very many outside of the state that are NYSERDA affiliated.
13 Oct 2014 08:39 PM
I am not sure what "affiliation" entails but nearly everyone recognizes Manual 'J'. If NYSERDA requires something special they should be able to direct you to their affiliates. Best of luck.
richmUser is Offline
23 Oct 2014 09:54 PM
krom,
I found this to be very informative and might answer your questions regarding "u" and "uglass". Or it might encourage additional investigation and/or calculations
http://www.greenbuildingadvisor.com/blogs/dept/guest-blogs/presumptive-european-superiority-syndrome?utm_source=eletter&utm_medium=eletter&utm_content=gba_eletter&utm_campaign=green-building-advisor-eletter
And, do you mean NYSERDA Affiliated or Approved - big difference!
Please let us know what you decide.
RichM
kromUser is Offline
Been reading that, and running numbers. I'll let you know.
Hopefully someone will come along who can recommend a designer, or consultant .
