Concealed Low Static Pressure Ducted Mini Air Handler
Last Post 22 Jul 2015 07:19 PM by ricky_005. 0 Replies.
ricky_005User is Offline
The concealed air handler would be located lets say in the master bedroom in the attic space above the exterior window. The return duct would be twice the size of the intake of the air handler but the length of the return would be lets say 32 feet long.
The idea is that the conditioned air would travel from the source across the bedroom through the bathroom and finely arrive at the return in the walk in closet.
It seem to me the units CMF spec's should not be affected by extremely long return if it is sized properly?
Spec for a Mitsubishi SEK-KD09NA4 air handler
Power Supply Phase, Cycle, Voltage 1 Phase, 60Hz, 208/230V *4
Cooling Rated Capacity 8100 Btu/h (2.37 kW) *1
Capacity Range 3800 - 10900 BTU/h (1.1 - 3.2 kW)
Total Input 670 W (0.700 kW)
Energy Efficiency SEER 15
Sensible Heat Factor 0.8
Heating at 47° F Rated Capacity 10900 Btu/h (3.2 kW) *2
Capacity Range 4800 - 14100 Btu/h (1.4 - 4.1 kW)
Total Input 1020 W
HSPF (Region IV) 10
Heating at 17° F Maximum Capacity 6700 Btu/h (2 kW)
COP 2.42 Btu/Btu
Minimum Circuit Ampacity MCA 1 Ampere
Recommended Fuse/Breaker Size
15 Ampere
Refrigerant Type R410A
External Static Pressure
0.02 -0.06-0.14 -0.20 In. WG (5 -15-35 -50 Pa)
Airflow Cooling : DRY 194-247-317 CFM (5-7-9 m³/min)
Cooling : WET 174-222-285 CFM (5-6-8 m³/min)
Heating : WET 174-222-285 CFM (5-6-8 m³/min)
Sound Pressure Level
23-26-30 dB(A)
Dimensions H x W x D Height 7-7/8 Inches (200 mm)
Width 39 Inches (990 mm)
Depth 27-9/16 Inches (700 mm)
