Green/Energy-Efficient Design and Planning
Cheapest foundation/Frost protected shallow foundation cost?
Last Post 06 Apr 2018 05:07 PM by
patonbike
. 44 Replies.
Oldest First
Most Recent First
Prev
Next
Page 3 of 3
1
2
3
Author
Messages
patonbike
21 Dec 2017 09:23 PM
ah, I realize now that the blocks are where they nail the siding into ... so they have more to bite into than just the plywood.
What about hot water heater.. tankless ?
I don't know about a heat pump HWH... ours is fine, but it's noisy and big. It's in a large unfinished heated basement so it works OK. Space is tight here.
Our water is mildly hard but not super hard.
patonbike
29 Dec 2017 09:20 PM
So after this week I decided I Want to heat the garage, however we will still put proper insulation in between garage ceiling and apartment floor upstairs.
If I insulate the garage portion and heat to ~38 or 40F, can I use plywood as the interior wall and Roxul insulation? Or do I need to use drywall and do we need a vapor barrier?
Dilettante
30 Dec 2017 05:28 AM
Basically, no matter what you do regarding insulation and finishing, code is going to require that you put up a vapor barrier and drywall. Fire and fume protection.
patonbike
02 Jan 2018 01:23 PM
Is that also the case for the garage walls? I know it is true for garage to apartment ceiling...
patonbike
Back to the garage and apartment - getting almost time to decide on insulation.
Have seen opinions range but most people around here are in the "just spray it" camp.
I am wondering about doing roxul in the walls and spray the ceilings plus spray any spots that are hard to get with roxul batts?
Will mixing and matching cause any issues?
Page 3 of 3
1
2
3
Membership:
croccohvacusa
People Online:
