Green/Energy-Efficient Design and Planning
greener roof construction
Last Post 06 May 2016 01:26 AM by
EstherBennett
. 4 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
Dale1968
15 Jan 2016 08:43 PM
Was looking for information regarding a double deck roof construction. Having the first sheathing laid over the trusses, then using diagonal 1x strips over that, then vertical 1x strips over that, then another layer of sheathing. The idea is to separate the hot deck from the attic space. Anyone have info on this type of roof construction? Or what it might be called? Thanks
16 Jan 2016 08:27 AM
You could call it a "above the rafters vented roof deck". The first layer can be rigid foam. But do it mostly for moisture reasons, not heat.
16 Jan 2016 08:28 AM
You could call it a "above the rafters vented roof deck". The bottom layer can be rigid foam. But do it mostly for moisture reasons, not heat.
Dale1968
16 Jan 2016 06:39 PM
I know it's been done mainly with tile and metal roofing but wondering if it's a feasible way to have a cooler attic space with standard shingles instead. Yeah I would do insulation above the first deck. Have any write ups about it?
EstherBennett
Thank you so much for asking this question. I also have the same doubt and could not find the perfect solution for this. Please help me out from this.
Membership:
croccohvacusa
People Online:
