"Canned"/off-the-shelf energy efficient home designs?
Last Post 20 Oct 2016 02:40 PM by kingsboy48. 19 Replies.
WannaBuildGreenUser is Offline
03 May 2016 06:33 PM
Is there any kind of source or repository of energy-efficient home designs that have actually been built? Clearly I can search the web for "new home plans" and get thousands of results. Searching for "energy efficient home plans" cuts down the results dramatically. But even within that more specific search, I find it hard to see the details that went into making the design high-performing. And I can't find anything for "energy efficient home plans that have been successfully executed".
What I want are designs that were created with energy efficiency/high performance in mind from the start, and actually built. We are hoping to build, and having something unique or one-of-a-kind is not a requirement. In fact, I'd actually prefer to use an "off the shelf" design. I could be wrong, but it just seems like going with something that's actually been built, tried and tested, a "known quantity" would have a better chance of having fewer surprises, everything working as expected, less unforeseen "gotchas", etc. I'd like to think I could also save some money on the architect's fee as well.
HiralpatelUser is Offline
04 May 2016 04:44 AM
Yes! There have been such designs, new as well as existing one where energy consumption was brought down by Energy Analysis as well as Building simulation. For Instance, A Dubai based company expected us to bring down energy costs by around 30% in constricted timeframe.
For that architectural engineering firm has prepared energy optimization reports & e-Quest model to enable them achieve the expected energy savings. One model was built in eQuest and another baseline 3D model in e-Quest as per standard ASHRAE 90.1-2007 were compared in order to evaluate the energy savings. Finally, the energy consumption report extracted and fruitfully able to achieve 29.72% energy saving.
I hope this helps!
jdebreeUser is Offline
04 May 2016 07:31 AM
One of the most important aspects of building an energy-efficient house is proper siting and orientation on the property, so stock plans suffer in that regard. A house really should be designed for the location that it will be built for many reasons, one of which being energy efficiency. Our house was designed for energy efficiency, and is performing very well, but it was designed for our specific climate, lot, and orientation. If I moved the exact same house to our lot we had in FL, it would be all wrong. I suppose you could look through stock plans and look for ones that work for the lot you have (or are planning), but even construction methods vary with climate.
04 May 2016 03:57 PM
Posted By Hiralpatel on 04 May 2016 04:44 AM
I hope this helps!
Are these designs available for others (i.e. me) to review and use?
04 May 2016 04:19 PM
Posted By jdebree on 04 May 2016 07:31 AM
I agree, that certainly makes sense. But I doubt it's a black-and-white affair, more of a shades-of-grey situation. The absolute perfect design is purpose-built to the lot/location: so take that perfectly designed and built house and move it to the lot across the street. It's likely now sub-optimal, but not wholly inappropriate. On the other hand, moving it to a wholly different part of the country is likely completely inappropriate.
I would think you could have canned designs bracketed by climate region. So I would start with stuff designed for my climate zone. And, the designs for neighboring climate zones probably don't need too much re-design to be made appropriate for my area.
Maybe another way to put it is this: I'd be happy with canned designs that are say "80% ideal" for my area. 100% ideal is custom-designed for my exact lot. But I'm looking for "pretty good" or "good enough", not necessarily absolute perfection. I am thinking of the 80/20 rule, which goes something like: You can get 80% of what you want with 20% of the effort; getting that last 20% of what you want costs 80% of the effort.
What I think would really be slick is some web-based software that is easy and intuitive enough for ordinary people to design their dream house. Start with a simple "wizard" that asks how many floors, basement yes/no, square footage, beds, baths, etc. It auto-generates stock floor-plans, then allows you to drag-n-drop the rooms around, and/or shrink/stretch walls to change dimensions. Furthermore, the "expert mode" would allow you to specify construction techniques, model thermodynamic performance, etc. And, it would all be backed by cost data (regional cost data would be killer) so you could price out the cost to build. And of course the plans could be then rendered into 3D so you could take a virtual walk through the home. My idea is something akin to what Kelley Blue Book (KBB) is to cars, you can price out your dream car with all the different options. I'm a technology guy, I believe this is completely doable. Anybody out there want to fund me to build it? :)
Bob IUser is Offline
04 May 2016 04:27 PM
As far as I know there are no web sites with pre-designed zero energy house plans. It's too soon and the demand is still low. There are of course architects who have designed and built several versions of similar houses, but the designs would still be proprietary. Your best bet is to find a basic house design (not too many corners & a simple roof) and find a builder who can built you a double wall version of it.
The builders you spoke to from the PHIUS website would probably be able to help if you can give them an approximate budget (including or not including land, site work, well, septic - just be clear which you are talking about) and some ideas about the house you want to build. I can verify that not knowing any of this information means that you can spend a lot of time heading down the wrong path with potential clients, to no one's benefit. As far as the insulation levels you are looking for, the typical "high performance" house in that climate often has R-40 walls, R-60 roof, triple glazed windows and a fully insulated basement or crawl space. Some builders specialize in expensive houses, some the opposite, and you can often look at their pictures and figure out what companies are the closest to what you're looking for.
10 May 2016 04:14 AM
Posted By WannaBuildGreen on 04 May 2016 04:19 PM
11 May 2016 07:52 AM
Posted By WannaBuildGreen on 04 May 2016 03:57 PM
I hope this helps!
I can not share design samples, however, If you want then I can help you with Building simulations, design support or energy modeling for building Energy efficient house.
HP HomeUser is Offline
11 May 2016 05:33 PM
A good house starts with a good design.
The more basic the shape the easier it is to make a tight enclosure.  A square box would work great but doesn't look that great.
Dormers, cantilevers, pop-outs, dropped soffits, attached garages, etc all make the tight enclosure thing more difficult.
South facing roofs with big overhangs are good.  Not just for solar but also to let the more durable cladding (the roofing) take the worst of the beating (the UV's).
If you want windows the majority of them should face south and as few as possible should face north.
Also with windows refer back to the big overhang roof thing and think about where the sun goes and when.
Basements and slabs are good, sealed conditioned crawlspaces are ok, vented crawlspaces are no good.  I would rather build on pilings than a vented crawlspace.
Mechanical equipment used to make heat or cold and all ductwork goes entirely within the conditioned enclosure.
Finding a set of stock plans that can accomplish this on your unique building site might be difficult.
12 May 2016 02:36 AM
Most "stock" designs are not done well and of course not site specific. I've seen some pretty crazy roof angles going all over the place which creates an energy, thermal, sealing and roof maintenance nightmare for the life of the home. A lot of these designs can negate any attempts of green energy designs. A wacky roof design that leaks air, has thermal bridging, and cannot be insulated correctly destroys any attempts to make it a well insulated home.
Most house designs throw windows all over the place without any sort of logical process to it. They have different sized windows in every room instead of using similar sized windows which makes it more economical and easier on the builder.
KirstenPeacheyUser is Offline
25 Jun 2016 05:48 AM
Nice discussions.
18 Jul 2016 02:09 PM
Since starting this thread, I'm further along in the building is a real possibility for us process. So it sounds like there's no such database of "canned" high performance/energy-efficient home designs.
However, we've narrowed down the details enough that I'd be surprised if someone hasn't already built a house that would meet our requirements. How to find that builder? I don't think we're looking for anything too terribly exotic or unusual: two-story with full basement, about 1500 SF per floor (4500 SF total counting basement). 4 bedrooms up, open main floor plan with office, roughed-in basement. Location: western suburbs of Chicago (Downers Grove). We're not going for full-on Passive House or other top-tier energy efficient specs, but something along the lines of a Pretty Good House.
The size/layout/style I've suggested above appears to be typical/common in the new construction we've seen, save the energy-efficient considerations. In other words, we've seen plenty of new builds that would work for us if only the builder had incorporated some high-performance features. I have to believe that someone is doing this in the greater Chicago area.
As per the intent of this thread, my intuition says that we can save time and money if we can find a builder who's already done a house that is what we want. Surely the builder can better plan to do a duplicate of a home he's already built, while at the same time run into fewer "gotchas".
Feel free to PM me if you're a builder in the greater Chicago area and willing to discuss this.
18 Jul 2016 05:50 PM
Since you are looking for a Passive House - or close - it makes the most sense to call builders who are registered with Passive House Institue, US, which is based in Chicago. Go to PHIUS.org and search for building professionals in your area. FYI, there are "consultants"and "raters" and "designers" who are builders, so look at all of the lists. It's very likely that a local architect or consultant or rater will know local builders if they aren't one themselves.
fvicfUser is Offline
21 Jul 2016 12:41 PM
Here is a builder in the area (Geneva, Illinois), I have no association with them. They built this: http://www.greenbuilthometour.org/project/chicagolands-first-certified-passive-house/
They may have some plans: http://evolutionaryhomebuilders.com/home-building/home-plans/
I also live in the far Western suburbs of Chicago, Batavia, and am considering building an energy efficient house. I'd be interested in what you decide. I've contemplated ICF vs double stud and depending on how much work I would do will really sway me. If I do a lot of the work I would lean toward ICF as it appears to provide similar performance (I know this is up for debate, but I'm not looking for R40+ walls) without the complexity of getting the walls sealed.
Mike
26 Jul 2016 05:37 PM
Posted By Bob I on 04 May 2016 04:27 PM
Well, this is frustrating. I haven't contacted all the companies listed on PHIUS, but most of the ones in the greater Chicago area. I'd say only 25% get back to me.
At this point, I've developed a form letter that basically says this: "I'm looking to build a high-performance/energy-efficient home in XYZ suburb. I am targeting the value sweet spot between code-min and Passive House, i.e. a Pretty Good House. My budget is $X. In the interest of saving time and money, I'd like to copy an existing design/build with these specs: (insert high-level specs here, e.g. floors, square footage, number of rooms, etc)."
I really don't think what I'm looking for is esoteric or even unique. In fact, if I omit the energy-efficient requirement, we've seen lots of houses in our target area with perfect floorplans. In fact, one builder we talked to said, "What you want is a pretty typical concept for the Western Suburbs." Yet I'm having a very low success rate getting through to anyone.
Any other tips or pointers?
arkie6User is Offline
26 Jul 2016 11:30 PM
Go down to the local builders supply (not Home Depot or Lowes) and ask to speak to the construction sales manager and ask him for recommended builders to contact.
27 Jul 2016 04:42 AM
Around here, it's hard to get a response out of any one. In hiring subs to do some work on our house, a good many never got back to me, others responded but never showed up, or came out and looked, but never gave me a quote. Business must be good!
27 Jul 2016 07:48 AM
the ZE builders I know are out straight - very busy. It's the middle of the building season, help and subs are hard to find so everyone is scrambling. Keep trying & call people back.
BillBraskeyUser is Offline
28 Jul 2016 03:27 PM
I'm in very much the same situation as the OP.  I live in the FL panhandle.  I'd appreciate any referrals to professionals in my area who would give me a consult on a custom home design for a specific property location.
kingsboy48User is Offline
Hi, you could consider SIPs (structurally insulated panels) homes. Very energy efficient and off the shelf designs are available such as from here; http://www.jmlcontracts.co.uk/sip-standard-designs/ Ok, that's in the UK but it's a good start to take to a SIPs panel manufacturer to work from and quote you. Good luck.
People Online People Online: Visitors Visitors: 332 Members Members: 0 Total Total: 332
