Best way to build a green warehouse suitable for living quarters?
Last Post 09 Feb 2023 03:50 AM by Cassy0110. 9 Replies.
Kung Fu Art HouseUser is Offline
04 May 2021 05:20 PM
Hello, I'm looking to build a relatively-inexpensive, energy-efficient, eco-friendly building that will last over a century. I don't care what it looks like on the outside if it meets those criteria. I want to put it on a 2000 sq' full basement, on a hilly several acre lot in Virginia, so it can be a full walkout with windows in one basement wall. The first floor would be half-living quarters + office/music studio, and the other half art gallery. 4 bathrooms total, two with showers; 2-3 composting? Tankless water and/or solar hot water? Cover the roof with solar panels. What are your ideas for construction materials/process to save money and build something energy-efficient that will be around long after I'm gone? Modular/pre-fab warehouse? Custom build? I have not purchased a lot yet; any tips on that are appreciated. I suppose commercial/residential. zoning or some non-HOA areas may be suitable? Floorplanner attached. Thx in advance.
kenmceUser is Offline
05 Aug 2022 10:03 PM
You have any interest in ICF?
07 Aug 2022 02:27 PM
PermaTherm steel SIPs , galvalume steel skins are suitable for permanent exterior cladding
25 Oct 2022 09:12 PM
Check into what the Earthship people do.
newbostonconstUser is Offline
26 Oct 2022 10:44 AM
ICF
27 Oct 2022 01:38 PM
Consider Structural Concrete Insulated Panels for the walls, floors and roof.
greenhouse17User is Offline
04 Nov 2022 11:40 PM
what is your total budget
Cassy0110User is Offline
22 Nov 2022 05:01 AM
have you applied to a real estate agency?
EmilyBUser is Offline
10 Jan 2023 10:06 PM
I'm in the process of building an eco-friendly family home but I've run into so many issues (energy sources, insulation expenses, unreliable suppliers etc) that I have well and truly blown my budget. I have such a long way to go and almost nothing has gone to plan. I would love any advice for achieving my green dream but keeping the costs down. What energy source did you go with? What exterior cladding did you use? Do you have any reputable suppliers for indoor bathroom and lighting fixtures who also value sustainability? I don't want to give up on this!
Here are some suggestions to consider:
Building Materials: Consider using sustainable building materials such as bamboo, recycled steel, and recycled wood for flooring, walls, and roofs. Bamboo is a rapidly renewable resource, and steel and wood can be easily recycled.
Insulation: Make sure to properly insulate your building to reduce heating and cooling costs. Options include spray foam insulation, cellulose insulation, and fiberglass insulation.
Heating and Cooling: Consider installing a geothermal heating and cooling system, which utilizes the stable temperature of the earth to efficiently regulate indoor temperatures. Another option is a heat pump system, which uses electricity to transfer heat from the outside air to the inside of your building.
Water Heating: Installing a tankless water heater and/or a solar hot water system will help reduce energy usage and costs.
Solar Panels: Covering your roof with solar panels will help you generate electricity, reduce your energy costs, and decrease your carbon footprint.
Windows: Make sure to install high-efficiency windows that are properly sealed to reduce heat loss and minimize air leakage.
People Online People Online: Visitors Visitors: 403 Members Members: 0 Total Total: 403
