Concrete block wall insulation
Last Post 10 May 2009 08:15 PM by mac31313. 23 Replies.
bmancanflyUser is Offline
06 May 2009 06:29 AM
Posted By mac31313 on 04/01/2009 5:54 PM
yes,
nail the fir strip to the concrete (on top of rmax) with 2 3/4"case hard nails,
you can tack rmax in place with small blocks or glue, seal joints, then add fir strips
mac
I think I'll be doing it the way you suggested.
When you say seal the joints ,  do you mean with tape?
mac31313User is Offline
09 May 2009 05:40 PM
Posted By bmancanfly on 05/06/2009 6:29 AM
yes,
mac
tape will work,
but i use foam in a can ....get the pro style(reusable gun with control...less mess)
seal to floor,between sheets as you go.... 1/4" bead
also foam around outlet and switch boxes, penetrations, doors and windows
mac
10 May 2009 08:54 AM
thanks for the info - very helpful. the insulation boards I bought have a tongue and groove joint, so they provide a real good conection.
Once last question. Do I have to use pressure treated furring strips since they will not have any direct contact with the concrete block?
re: pressure treated strips
the only one required to be treated is where you have contact with masonry
(sometimes i use one along floor)
mac
