Green/Energy-Efficient Building and Construction
Bad idea?
Last Post 04 May 2009 08:17 AM by
Brawler
. 6 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
Brawler
23 Apr 2009 10:21 AM
I have extra 1" dow foam board left over from my under slab insulation. Should i place this against the outside of the Superior Walls, outside of the plastic drain sheating to gain alittle more R value before i backfill? What would be the downside. The board was free and i am starting to backfill in a couple days. My only concerns are insects and the fact that the airgap behind the plastic drain sheet would negate any gain. Thanks Michael
Attachment: waterproofing and trusses view SW.jpg
Attachment: pre backfill view N.jpg
newbiejohn
24 Apr 2009 07:56 AM
What is the name of that membrane you have already in place ?
Oh and sorry im a newbie and unsure about the specifics of your question or I would help in a heartbeat.
ibgreen
24 Apr 2009 11:16 AM
brawler, There was a report regarding the problem of XPS water absorption. Search the site. Under your slab should not be a problem, but around the perimeter I would be hesitant. You are probably better off adding to the inside of the wall cavities and/or backing the perimeter floor bands of your webbed trusses.
aardvarcus
24 Apr 2009 12:08 PM
Dow foam board is used for that all the time around where I live. One of the most important reasons to use it is that it protects your waterproof coating during backfill, besides the extra Rs.
thagreen
24 Apr 2009 01:52 PM
Since it was a freebie, why not! Please do install on the outside face for all advantages are outside use. I don't think the air gap should be of any concern. Overall I only see advantages.
Cheers!
Brawler
28 Apr 2009 09:13 AM
Thanks for the replies guys. I think I will use what i have. Soryy for the delay, had to leave town for a couple days. I will let you know how it goes.
Brawler
newbejohn, typar Delta drain
Membership:
croccohvacusa
People Online:
