I always bend rebar from the lower footing upward, and from the upper footing downward to create an overlap. When i do the vertical step with FAD as you mention, i put plywood or osb in both the front and the rear of the vertcial step, and run 3/8" or 1/2" dia bolts thru the plywood to sandwich the fad in between. I guess you could screw the plywood to he fad, but I would not trust fad to hold screws under the concrete pressure. I then pour this area about 1/2 full, then come back when concrete has set a bit to finish off.
Bunt
