Ridge Or Maximum Vent
Last Post 25 May 2009 06:46 AM by thagreen. 2 Replies.
thagreenUser is Offline
22 May 2009 01:20 PM
Hy people,
Laying a tin roof and can't decide weather to do ridge vent or maximum. I know the maximum is much more effective however it will put more holes in the tin and sealing all around, w/touch-ups every so often.
With the ridge vent all is done and don't need as much maintenance, however the rep. I spoke to says the holes ,similar to soffit, will get clogued and lose efficiency.
Any thoughts, alternatives.
Tnks.&Cheers
22 May 2009 07:46 PM
I am not familar with the 'maximum' vent you mention. Could you elaborate on the product and its usage.
Back in the day when I used ventilated attic space, continuous ridge vents, along with continuous soffit vents, were (and are) considered the best method of venting. I have never heard of either clogging up. And trust me, the fewer holes you put in a roof the better off you are.
Maximum vent is a square which sticks out about two feet or so from the roof surface ,chimney like made out of tin, and vents 3 to 5 hundred square foot of attic space per vent.
My thoughts were the same as yours regarding fewer holes the better.
There will be soffit vents all around to help vent.
People Online People Online: Visitors Visitors: 353 Members Members: 0 Total Total: 353
