Posted By rbisys1 on 23 Sep 2011 01:50 PM
Greetings,
Going with a 2x4 construction and using 3 layer radiant barriers (RB) in ceiling and walls will give you a more energy efficient home, plus you don't lose the sq ft and you don't have all the associated building and operating problems.
More BS?
Not even the manufacturers buy that story. To meet code min in a 2x4 wall with foil you'd need 10 layers or more:
http://www.comparethemultifoil.com/In real building assemblies the effect of low numbers of reflective layers on whole-assembly U-values can be surmised from the results of this fairly straightforward experiment:
http://www.cchrc.org/docs/reports/T...imates.pdf(More gummint conspiracies, I know...
