Jerry D. Coombs, PE
| 25 Jul 2009 07:50 AM |
In most instances you have to think of the straw bale walls simply as insulation. For load bearing walls you still need some sort of framing support. Sometimes you can get away with just the bale support, but the system must be able to tolerate large movement. I strongly suggest hiring a structural engineer to look at these walls and the entire framing system. As a matter of fact it is a code requirement.
<br>You can have with quality; You can have it fast; You can have it cheap. Pick any two. |
