Fascia recommendations
Last Post 01 Sep 2009 06:07 AM by CTerrian. 5 Replies.
CTerrianUser is Offline
19 Aug 2009 01:20 PM
Our trim and fascia is showing signs of wear, so I got an estimate to replace from a local contractor. He recommends James Hardie boards.  The siding and trim on our chimney requires repair, so he recommend Hardie siding around that.
 I've been doing some research, and can't find how much it even costs. The fascia boards are approximately 3/4"x6"x12'.  I've also read some bad things about Hardie trim and siding on these forums, so I'm hesitant to buy it.
Any recommendations?
http://img2.pict.com/cc/90/f2/1458771/0/a.jpg
19 Aug 2009 01:24 PM
You might want to look at cellular PVC.  It holds paint well without soaking up moisture.  I have used it around windows for exterior trim with HardiePlank siding and I think it will probably outlast the HardiePlank.  See if you can find the size you need and then compare it to other materials.
BuntlyUser is Offline
19 Aug 2009 02:52 PM
I'm not big on low maintenance,...I'm big on no maintenance! I'd wrap with aluminum!
Bunt
Bunt
jimchoffUser is Offline
31 Aug 2009 06:31 PM
No maintenance...that's me.  My new home will have metal fascia, same color as the metal roofs!
Jim
trim42User is Offline
01 Sep 2009 05:19 AM
Word of caution...one bad thing about using wood on the exterior of a home is that it is suseptible to rot; one good thing about using wood is that it is suseptible to rot. WHAT?
Black/Green mold spotting & rotting wood are signs of a problem, be it water infiltration or lack of conditions that allow the wood to dry out. USUALLY, wood on the outside will indicate a problem before it gets too severe. With PVC or Hardie Board, framing members may be virtually non-existant from rot with no indication on the outside. When using these products, make EVERY effort to insure that moisture will not be a problem behind them. Flash everything well and use a liberal bead of a high quality urethane caulk.
Thanks for all your input. After considering all the options, we decided to go with the new Hardie board. I considered the "no maintenance" option, but masking the trim with aluminum wasn't a total solution, as the underlying wood would continue to rot.
I had it done by a professional, and he informed me about all the caulking and painting that is required for a long lasting finish.
Thanks again guys!
