Need energy efficient ideas for caboose motel
Last Post 09 Nov 2009 04:55 PM by jmorberg. 3 Replies.
jmorbergUser is Offline
08 Nov 2009 09:16 PM
Looking at building some replica cabooses for a hotel project in Eastern Washington. 300 to 400 sq feet. 300 + days of sun per year, hot summers, cold winters. I would like to utilize solar, and I have heard about the solar skin, but maybe go with the flat panels. I am looking for suggestions on heating and cooling systems. Building with a very tight, efficient build. Gas is not available, so only propane and electricity. Thanks
aardvarcusUser is Offline
09 Nov 2009 04:22 PM
What kind of R value will the cabooses have? What kind of windows? I would lean towards a small mini-split unit with a heat pump. On a cost per BTU basis, where I live propane is fairly pricy, so unless your propane is cheaper, I would rely on the heat pump in the winter, and on the coldest days have a resistance electric backup.
09 Nov 2009 04:36 PM
They will be built from the ground up, so looking at best options for siding, SIP panel way to go? as well as window options. I am working on a budget. I would love to use solar in any capacity due to all the sun the area gets. What most of the new construction has done there is the heat pump. I know some hotels use a heat pump for each room, what is the best kind??
Steve
This is the company that builds the kit, and then you take it from there, Looking for all the neat green ideas to incorporate something this small.
http://www.dogpatchandwesternrr.com/
This is the look to achieve:
http://www.guestcaboose.com/Rates.html
People Online People Online: Visitors Visitors: 422 Members Members: 0 Total Total: 422
