It's probably less cutting (but more pieces) to go ahead and cut a piece that fits up flat against the band joist, then another to lie flat atop the foundation sill to come back & meet the flat piece you're applying to the wall than to try & cut in all of those notches with reasonable precision. Both the piece against the band joist and the piece against the sill will be the same width, and are probably reasonably consitent from joist to joist, so you can just rip a piece that width (maybe 1/2" narrower than that width), and cut them to length as you go, then foam them in place with the gap you've allowed. Then putting the foundation bits up against the one over the sill plate & foaming that seam will be dead-easy.
You may still end up with a small cavity under the insulation between the sill plate and the foam on the wall, but it'll be much smaller. But you'll end up with the bottom plate/flooring of the wall above being inside rather than outside the insulation, and less prone to mold/rot since it's warmer, and at the same humidity as the basement. |
