Green/Energy-Efficient Building and Construction
Heating source? To heat radient
Last Post 16 Jan 2010 09:21 PM by
thomas c
. 2 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
thomas c
10 Jan 2010 07:40 AM
I am having a geothermal system installed in my house this week. My next project is to get heat in my shop.
I am going to be installing radiant in floor heating. The building is 50' x 48' with no interior walls. The engineering calculated a total heating load of 36000 btu/hour and a total radiant load of 33180btu/hour. RFH Glycol level 30%. Design temp drop 15 degrees f. radiant tubing volume 39.1 us Gallons. Total flow rate 5 usgpm.
I was going to go with a propane tankless water heater, but the water to water geo system is interesting to me.
I plan at keeping this building at low temp approx 55-60f
I will only be working in this building some nights and weekends.
Any sugestions would be greatly appreciated.
Thomas
egouin
12 Jan 2010 07:10 AM
Thinking aloud... If you are going to be heating a large slab of cement, geo may take a long time to get that slab up to the temp you want. While geo is my first choice for space heating, it has to make sense. The on demand propane can produce much higher temps more quickly. This will get your shop up to the temp you want quicker. For occasional use, I am not sure the economics of geo will be favorable compared to a $1,000 on demand burner, some pex tubing, and occasional propane use.
Just my opinion.
Ed
http://www.GouinGreen.com<br>Superinsulated SIP/Modular House (HERS = 30)<br>GSHP w/SCW, ERV, Passive Solar, Solar HW
thomas c
I would like it to be heated all winter at around 55F all winter. 24/7
Membership:
croccohvacusa
People Online:
