Plastispan under foundation?
Last Post 19 Apr 2010 09:50 PM by terrynew. 3 Replies.
terrynewUser is Offline
10 Apr 2010 09:50 PM
Hi, I'm building a 1-floor slab on grade house in a cold Ontario climate. I had planned on putting 4" of SM under the slab but my general contractor recommends an EPS called Plastispan (www.plastifab.com) He can get it the HD version, R4.5, 30% cheaper than SM, and it's rated for foundation use. Anyone have any experience with it, or with other closed-cell EPS boards under a slab?
...Terry
thagreenUser is Offline
12 Apr 2010 10:42 AM
Yes ! Fond an independant study awhile back and stated that eps keeps its R longer than xps when used under ground. It also sucks up less water over time.
Green Build ABUser is Offline
15 Apr 2010 10:50 PM
I was not aware of the study referred to by thagreen. I put plastspan under my slab as well. I had questions so called Plastispan in Edmonton. He was really helpful. They make a product called Insulworks for under slab that is used for radiant heating. Made installation really slick. They also make a product for the exterior walls - custom cut channels for furrow strips. Great people to work with
Green Build AB: I believe it's Beaver Plastics of Edmonton that makes Insulworks, not Plastispan (see www.beaverplastics.com). It looks like a similar EPS, but with slots for the radiant heating pipes. Thanks for pointing it out.
...Terry
People Online People Online: Visitors Visitors: 294 Members Members: 0 Total Total: 294
