Nobody has responded to my query, but here's an elaboration that might provoke some thought. The woodstove is on the opposite side of the wall to the utility room, so I'll be running an HRV house supply duct through a ceiling bulkhead right beside the wood stove chimney. I wondered if there was any value in essentially splitting the duct to a 'Y' that forks on either side of the black chimney, hugging it somehow so that air heading into the rooms picks up some of the heat heading up the chimney.
The chimney is double-insulated so that would restrict heat transfer; I don't know if Ontario code would allow me to remove the outer layer within this passive heat exchange box, but I'm sure it would at least raise a challenge from my local building inspector! More importantly, would this fail to transfer any heat to the HRV air because it's passing by quickly and over a small area?
Thanks for this and for any other related ideas you may have! ...Terry
