Posted By Randy Navarro on 23 Apr 2010 11:45 AM
Thanks for the replies.
I'm hesitant to drop any foam on the outside of the stem wall here the PNW. As a home inspector, I've seen too many carpenter ants tunnel right through the foam--especially the XPS (white beads.)
I probably don't have too many options other than the traditional: 2" EPS on the inside of the stem wall flush with the top of the stem wall (or beveled at the top) and then pour the slab.
Open to other ideas still . . .
Scratchin' my head over foam. . .
Borate loaded EPS (eg Performgard) pretty resistant to ants & termites, even in below-grade applications, if that's a real concern.
BTW: XPS is never white beads, EPS is. Both are good for under-slab insulation, but XPS is more vapor retardent, and has a ~25% higher R value for any given thickness. EPS is usually cheaper per unit-R.
