Green/Energy-Efficient Building and Construction
insulation for pex
Last Post 31 May 2010 09:02 PM by
Como
. 2 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
Stonelake
30 May 2010 05:06 PM
We will be using pex tubing for domestic water supply under a slab. Should we insulate both hot and cold water lines all the way from the manifold ? Is there a difference in the types of insulation available? Should we consider running the pex in PVC pipe in case of a problem later ? How easy is pex to pull through PVC pipe? How do we support the pex tubing from where it exits the wall and to the fixture? For example a toilet ? Is the "home run" concept the best, or use a larger size main like 3/4 " and branch off with 1/2 " to fixtures?
greentree
31 May 2010 01:25 PM
Those are all questions your plumber will handle.
Como
Larger size for the main.
I like to circulate the hot water because we have water issues outweighing heat issues.
Personally I do not like running pipes were I can not get to it if something goes wrong.
Insulation, well that depends on your situation.
Membership:
croccohvacusa
People Online:
