insulation for pex
Last Post 31 May 2010 09:02 PM by Como. 2 Replies.
StonelakeUser is Offline
30 May 2010 05:06 PM
We will be using pex tubing for domestic water supply under a slab.  Should we insulate both hot and cold water lines all the way from the manifold ? Is there a difference in the types of insulation available?  Should we consider running the pex in PVC pipe in case of a problem later ?  How easy is pex to pull through PVC pipe?   How do we support the pex tubing from where it exits the wall and to the fixture? For example a toilet ?  Is the "home run" concept the best, or use a larger size main like 3/4 "  and branch off with 1/2 " to fixtures?
greentreeUser is Offline
31 May 2010 01:25 PM
Those are all questions your plumber will handle.
ComoUser is Offline
Larger size for the main.
I like to circulate the hot water because we have water issues outweighing heat issues.
Personally I do not like running pipes were I can not get to it if something goes wrong.
Insulation, well that depends on your situation.
People Online People Online: Visitors Visitors: 298 Members Members: 0 Total Total: 298
