Posted By toddm on 14 Jun 2010 12:06 PM
Thanks Dana. The friendly neighborhood roofing supply carries 20 psi polyiso. sufficient? A planned container garden will create localized weight issues.
Considering that 1lb density XPS is only good for ~15psi, I think you'd be good to go, eh?
The more typical 1.8-2lb XPS is good to about 25-30psi, (which is overkill.)
Unless you're planting a giant Sequoia or Redwood, your planter isn't likely cause an issue. 20psi is about 1.5 TONS per square foot(!), at which point I'd worry more about stressing the framing than the insulation. If you were using a 100mm thick half-meter tall uranium pot as the container you might run into localized loading issues, but a damp-dirt & ceramic or wood thingy, fuggedaboudit!
