insulation cover-up
Last Post 21 Sep 2010 08:25 AM by vb. 2 Replies.
StonelakeUser is Offline
21 Sep 2010 12:00 AM
We are using termite resistant insulation on the exterior foundation of our slab with in floor heat home. The amount of insulation extending above grade will be  a little as possible , but has to be shielded from UV. I would like to cover it with a product that is durable and maintenance free.  Some have suggested using stucco, but I worry about staining. The termite shield extends over the top of the 2" styrofoam then 90's down a good inch which locked the sheets in well in place prior to back filling, but still has a little room . I would like to find a product   that is good for earth contact that is available in widths up to 12", that I could slip in between foam and shield lip on top, and back fill against the bottom to hold in place. Any suggestions?? Are there any adhesives that work with styrofoam ?
21 Sep 2010 07:30 AM
Stonelake you could use .019 painted  aluminum coil stock, it is available in several colors, 12 - 24" widths  it can be adhered with many different contrusrion adhesives , just check the label for EPS compatibility.
vbUser is Offline
I used a product called "Prep coat B-2000" by Durock. It is a stucco like- parge coating designed for ICF's. You mix it with water, spread a thin base coat, then you apply a fiberglass mesh, wait for it to dry and apply a second coat. It's only been on for 6 months so I cannot attest to it's longevity yet, but it went on very easy. I might paint it eventually but I only have about 6" exposed between the ground and the flashing, and it looks good the way it is. (It looks like concrete).
People Online People Online: Visitors Visitors: 278 Members Members: 0 Total Total: 278
