I've turned over and over my insulation equation for a 6000 gutted 2x4 frame, 3 story, 6 unit building, in jersey city, nj. The top floor has no attic. Ceilings are finished to the roof deck.
I decided to go for icynene ldr50 foam: 3.5" studs, 8" between rafters roof, 5" in attic floor. I almost gave my deposit to the installer, but then started reading nightmarish stories about offgassing, the toxicity of fire retardants, the chemical waste involved in the process and why don't we use cotton, wool or demin etc...
Here's a couple links:
http://blogs.howstuffworks.com/2009/05/14/how-icynene-foam-insulation-works/http://www.greenbuildingadvisor.com/community/forum/green-products-and-materials/14537/out-gassing-bad-stuff-spray-foam-insulationThe challenge with batt methods is my studs run from 13" to 18", many are not straight, some are cut by diagonals. Cutting batts of any kind isn't going to end up with a tight envelope. Wet sprayed cellulose is tough to find although I havn't looked too hard yet...
I would appreciate any feedback about icynene or advice about alternatives.
Thank you!!
